luck-man's Avatar
944 Power Steering Plug?
After replacing the pressure side power steering hose I noticed some seepage of fluid coming from a rubber plug near the driver's side rack boot. I touched it and it immediately fell off with some power steering fluid leaking out behind it. Can anyone fill me in as to what this plug is for? It disintegrated in the hole and I fished out what was left but now I'm not sure as to what I should use to replace it since I can't seem to find any mention of a power steering drainage plug. Anyone have this same problem with their power steering for an '86 944 by chance?
M.L.
Old 01-19-2007, 01:56 PM
Mine did the same thing. If I remember there is an adjustment under the plug, it is not a drain plug. I think that if there is fluid coming out of there you may need to reseal the rack. I remember it is a 1mm thread pitch but not sure if it is 10mm or 12mm, in case you want to put a short bolt and washer in there.
Lou
'87 944 na, sold to a friend
'89 951, Weltmeister chips, 3mm WG shim, 968 CS sway bars, stock looking engine bay, just turned over 125K miles. I run Redline oil.
Old 01-19-2007, 03:53 PM
luck-man's Avatar
Thanks! I'll try getting a short bolt and washer and then test it for leaks before proceeding.
M.L.
Old 01-19-2007, 05:48 PM
I think this is a cross side soft line tap (equalizer). very low pressure. I'm capping mine as we speak on a manual power to steering rack conversion. You can see the picture of the plug that is simply press fit. Sorry I don't have my PET file at home or I would shoot you the Part number.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 01-19-2007, 10:32 PM
A VERY short bolt, you will have to cut it. It only needs to be about 1/2" long. On the old 924 without power steering you ground a point on a 2" bolt and screwed it into a dimple on the rack to lock the rack on dead center.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 01-20-2007, 08:38 AM
luck-man's Avatar
Thanks for the info guys-I have a 10mm bolt along with a rubber grommet in there now but I was also wondering if just a simple rubber plug tapped in would do the job as well? I'm not sure why a regular bolt with a washer was not put in there in the original design since it seems like it would have been a more durable fixture.
M.L.
Old 01-20-2007, 01:46 PM
