Graduated User
conkeytonk's Avatar
Springs and...uh...dealers?
The spring tensioner that holds the exterior mirror from flopping around decided to let go. Go figure! Just how does one re-tension the mirror onto its housing and does anyone know of a source for new spring bushings outside of a dealer? Or for that matter, is there an online OE Porsche parts dealer in cyberspace?
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 01-24-2007, 04:25 PM
SoCal Driver's Avatar
Pull the wires through the bolt and use a 12 point 12 mm bit and a bunch of pressure to screw the base back onto the mirror mounting. Apply a bit of Loctite to the threads first.
The bit is the same as is used on the flywheel to crank bolts.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-24-2007, 04:31 PM
Graduated User
conkeytonk's Avatar
Hey SoCal, but what do you mean by "pull the wires through the bolt" and what is a 12 mm bit (a socket?)? Locktie in this application makes a helava lota sense.
Randy
Old 01-24-2007, 04:37 PM
Graduated User
conkeytonk's Avatar
Okay, now that my brain is working logically I think I've got it. Once wires are secured, first screw the mirror housing onto its base soaped with locktite, then press down hard onto the base/housing assembly and secure with the Allen bolt using a 12 mm hex socket. I'll give it a shot. Do I require therapy or have I got it right? Thanks again, and again Hugh!
Randy
Old 01-24-2007, 05:00 PM
Once you get the technique down, will you fix mine for a case of beer, before the damn thing falls off?
Red 1967 Saab "96", needs help
Blue 2002 Pathfinder SE
1991 240SX-SE, auto, trans was shot - junked it
Old 01-24-2007, 06:17 PM
If the bolt is still treaded you can use a large screwdriver by wedging it into the splines and turning. Push the wire bundle to the side. You may scar the wire bundle sheath just don't cut any wires with the screwdriver blade.
Check the local VW or an after market shop for BMW's for tools.
If the threads are striped out you will have to get another housing. Should be able to find one in the same color as your car. The bases are supposed to be different; early verses late.
Old 01-24-2007, 08:28 PM
12 point tool is just like a hex tool but with 12 points instead of 6...
Commonly called 'cheeseheads,' '12 point internal tools,' and something else.
VW's use them for headstuds, Chevy's use them for something or other, and Porsches use them for CV joints and apparently the mirrors?
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 01-24-2007, 09:46 PM
Graduated User
conkeytonk's Avatar
The mirror housing does not appear stripped Socal but I cant figure how it came separated from the housing and unfortunately it is.
Okay, cheeseheads; now Ive really got it. Have a complete set of em and your right Pozican, I have removed many VW cylinder heads and CV joints with em as well as recently the camshaft sprocket bolt for the 944.
If I figure it out Harpman2, I would be happy to help. Getting the mirror off without destroying wires or plastic parts was a trick in itself. You feel up to a cruise to sunny Florida one weekend? BTW, I drink Bud Red.
Thanks again guys, Ill try and finish her up Friday evening and let you know how it went.
Randy
Old 01-25-2007, 03:14 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Ok, sounds like all of us with loose mirrors are crashing at Randy's house to get our mirrors fixed...how does spring break weekend sound? Exactly how far are you from the beach? Now..how do I loosen my mirror and make it easy to fix?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 01-25-2007, 09:09 AM
Graduated User
conkeytonk's Avatar
Aim for the edge of the garage door while intoxicated and hope for decapitation of the mirror without further body damage.
Any excuse for a beach trip!
Randy
Old 01-25-2007, 10:12 AM
