-   -   Bizarre Problem - HELP!! (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/326838-bizarre-problem-help.html)
CJFusco 01-25-2007 11:08 AM
I was finishing up installing the 951Max chips into my car, when, tightening down the banjo bolt for the KLR, the threaded section of the bolt snapped off in the KLR housing. I was even using extra care in working with this banjo bolt, because I didnt want to lose the rubber sealing washers.
So, now I have a useless banjo bolt and a KLR with half a banjo bolt stuck inside. What do I do?!?
http://forums.pelicanparts.com/uploa...1169752092.jpg
http://forums.pelicanparts.com/uploa...1169752097.jpg
nynor 01-25-2007 11:36 AM
well, its already hollow. use a reverse tap thingy (can't remember what it is called) to get it out. i may have a new banjo bolt, if you need it.
CJFusco 01-25-2007 11:43 AM
i'm headed down to Bristol Motor Works now, to see if I can get it taken care of ASAP. I will let you know, RE the banjo bolt.
nynor 01-25-2007 11:54 AM
you can the tool you need at sears for cheap... bolt extractor tool, or something like that.
nynor 01-25-2007 11:57 AM
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&pid=00999067000&cat= Hand+Tools,+General+Purpose&subcat=Bolt-Out,+Taps+%26+Dies&vertical=TOOL&ihtoken=1
CJFusco 01-25-2007 12:28 PM
Got the bolt out fairly easy. Bristol Motor Works just called to tell me they DON'T have the banjo bolt I need. Do you have one for me, nynor?
Does anyone else have one, if nynor doesn't?
CJFusco 01-25-2007 01:03 PM
It's on its way. Thanks, nynor. Things move quickly in the Porsche community :)
nynor 01-25-2007 01:30 PM
yup, on its way. should be there monday or tuesday. 54 cents is cheap happiness ;)
Razorback1980 01-25-2007 02:42 PM
Your local FLAPS may even carry that bolt.
nynor 01-25-2007 03:12 PM
um... flaps?
pozican 01-25-2007 03:36 PM
Friendly Local Auto Parts Store
nynor 01-25-2007 03:49 PM
ah... LOL!
Basquiat 01-25-2007 04:37 PM
based on that pic, what's the difference between this banjo bolt and the coolant bleeder screw? They look very similar.
nynor 01-25-2007 07:03 PM
not sure of the size of the bleeder screw, but the banjo bolt is tiny.
CJFusco 01-25-2007 08:59 PM
Well, it's on its way, and if we get snow I won't be driving the 951 anyhow.
Although even driving the 951 on snow, ice, salt, and sand would be better than the alternative:
http://forums.pelicanparts.com/off-topic-discussions/326945-fun-extreme-temperatures.html
toolboy62 01-26-2007 03:47 AM
Where do you live? My FLAPS doesn't even carry the washers for a banjo bolt, I had to order them from the dealer. (just BTDT on the girlie's Corrado, the oil lines to the supercharger are banjos)
nate
Basquiat 01-26-2007 03:51 AM
The bleeder screw cost me 6 bucks from Brumos. That'sprobabaly 3 bucks to the rest of the world, but I'd go ahead and ask them if time is of the essence here.
