I'm with Bill
Rick V's Avatar
Great snowmobile
Well it was bound to happen sooner or later, we got a fair amount of snow last night. With the choices in my driveway the 44 was chosen to trudge through the winter wonderland this morning, pre plow help. This thing was great, I was very impressed. Being an S it is a little weak under 3500 so it was easy to keep it out of the "band" and still have enough to pull hills. I have a feeling this thing will go in a deep snow very well, as long as I don't get hung.
Anybody else like thier 44 in the snow?
I had to do the obligatory doughnuts in the parking lot at work, while my boss just shook his head.
Old 02-07-2007, 02:50 PM
meister member
speedracing944's Avatar
Re: Great snowmobile
I bought my 944 9-10 years ago in December. It started snowing that night so I had to drive her home in about 3 inches of snow. I thought the car did quite well since about 50% of the weight is over the rear axle. It was nothing like the old rear wheel drive American cars I have driven in the snow.
BTW it is a good time to practice your low speed drifting manuvers
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 02-07-2007, 03:11 PM
Redline Racer
HondaDustR's Avatar
ATM mine is not great, as it needs an alignment, the tires appear to be more of a dry tire (Pirreli's), and the fronts are worn on the insides due to the bad alignment. It really wants to swap ends under any amount of wheelspin. I bet it would be fun if it was better set up for it. Or maybe it's just me being a wimp
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 02-07-2007, 04:11 PM
That Guy
Techno Duck's Avatar
Doing donuts in a rear wheel drive car is inevitable.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-07-2007, 04:19 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I've found the 944 to be a very nice snow car, but have only driven it with the summer-only AVS ES100s on it which makes it pretty worthless - it's well balanced and controllable, just has no traction. I just bought snow tires for it, and it did actually snow last night, but the car is currently in the care of a local mechanic to sort out some issues
nate
1988 944... and a bunch of other cars
Old 02-07-2007, 04:21 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Go out and get a winter beater. $500 Subaru wagon AWD.
Can you say AWD donuts? I literally had the car spinning like a tank...it was amazingly fun and I highly recommend buying a Subaru just for this reason!
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 02-07-2007, 06:10 PM
Send a message via ICQ to Stoutpants Send a message via AIM to Stoutpants Send a message via Yahoo to Stoutpants
Unfortunately, the one week I have snow my dad has his Subaru in the shop. So I couldn't steal it from him. My 944 kinda scares me in the snow, the rear won't follow the nose.
Old 02-08-2007, 02:58 AM
Schumi's Avatar
We had about 2 inches last week.. thought about taking the 924S for some donuts.... but didn't as it was thawing and it would have gotten it too dirty.. so it sits under a cover in a heated garage.
M
Old 02-08-2007, 04:43 AM
I have 4 205mm Blizzaks on mine and it goes like a tank. I haven't been stuck all winter. You need to be confident with the gas and have a sense of what is 'about' to happen because you need to keep your foot in it to avoid getting stuck. But, aside from that, it goes okay. With the ABS (which I usually dislike in a car) I have to say that it does stop straight and has no tendency to swap ends under braking at all.
I do notice one odd thing though. When the car is idling, the temperature of the hot air drops to luke warm almost immediately. It's annoying. Ideas?
Remember our friends: Warren, Ron, Grady, and Steve.
76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3; 23 Cayman GTS 4.0; 97 Boxster
Old 02-08-2007, 07:52 AM
Redline Racer
HondaDustR's Avatar
Maybe a weak water pump or a clogged heater core.
Old 02-08-2007, 08:51 AM
Is there a way to flush the heater core?
Old 02-08-2007, 09:54 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
You can do a regualar radiator flush and turn the heater to full heat which will flush the heater core at the same time as the radiator. If you want to do the heater core by itself, then use the pipe going along the bottom of the cam tower and the heater control valve at the back of the engine to run hoses from and flush manually. To do the heater core by itself, you would need to connect a hose to both of those pipes and it would require a water pump in the middle to get the water/flush to flow through the heater core.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 02-08-2007, 10:14 AM
Thanks. Sounds like a spring time job. I have no heated garage right now and it's about 10 degrees. I hate winter.
Old 02-08-2007, 10:24 AM
Yeah, it's pretty cold here today too. It only got up to 75. I almost had to put my jacket on. That wasn't very nice was it?
Tom
Old 02-08-2007, 12:15 PM
I'm with Bill
Rick V's Avatar
Tom, Please take this with the humor it is intended to be.....................UP YOURS! We warmed up to 32 today
Old 02-08-2007, 02:50 PM
LOL....paybacks are in August!
Tom
Old 02-08-2007, 03:06 PM
