question about air aux valve
I took the valve off and put it in warm environment - after a while it closed, Then i put it in the freezer overnight - when i took it out it was partly open (very little hole) - so question is - is it supposed to open fully when its cold?
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 03-14-2007, 07:56 AM
SoCal Driver's Avatar
Idle valve on early 944's is supposed to be open when cold. There is a heating element in the unit that causes the bi-metal spring to expand and close the gate. This would lower the idle rpm's. Many times the gate is clogged up with old oil and other crank case residue. Use carb/brake cleaner.
Later 944's use an active or servo valve to control the idle through the DME.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-14-2007, 12:41 PM
used carb cleaner, had it sit in it for a bit, then moved the diaphragm open and close manually - no problems, but it doesn't do it on its own, just keeps it closed all the time with less than 1/4 of the hole opened.
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 03-14-2007, 12:49 PM
Could be that 1/4 open is all it takes to raise the idle the necessary amount. I have not looked through an early idle valve so I can't tell you if 1/4 open is typical.
Old 03-14-2007, 01:22 PM
Does anyone know if the valve is supposed to open fully when cold (after about 6hrs in the freezer)
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 03-14-2007, 06:32 PM
badjones's Avatar
Hey there. Was there symptoms of low idle when cold? I'm no expert but I'm fairly certain that the valve does not open fully when cold, and that the specific shape of the opening that is exposed when cold is tuned to the airflow need of the motor to raise idle the correct amount. The only variation between the 944 part and the other many types of very similar valves in other vehicles that look identicle is the cutaway shape in the valve. The valve travel is adjustable and I have tuned them by applying power to the plug and waiting till the valve has stopped closing ( a minute or so ), and then setting the adjustment so that the valve is just closed fully. Works for me.
83 944. Guards Red
drive it like you stole it.... http://www.pelicanparts.com/gallery/badjones
Old 03-15-2007, 01:28 AM
how do you set the adjustment?
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 03-15-2007, 03:36 AM
badjones's Avatar
You will find it shouldn't need adjusting but if its not closing fully there is a 7mm nut on a stud on the main valve housing that can be loosened and moved. If you adjust that so the valve only just shuts fully after having 12volts applied for a minute or so then you know it is adjusted to open as far as possible when cold, giving the greatest airflow when cold. This assumes that the valve is not blocked up with crap.
83 944. Guards Red
Old 03-15-2007, 01:17 PM
