Sensor connections
Hey Friends.
Small issue. The connectors to my speed and reference sensors are cracked and held together with superglue, gasket sealant, duct tape and wishful thinking. I don't need new sensors as the old ones are fine. It all works, but it doesn't give me a secure and confident feeling. Does anyone know where I can get new connector ends? Should I just replace both sides while I am at it? Has anyone done this before? Any suggestions for replacement connectors? Thx in advance. |
Plug 022.906.231.A
spring N 903.353.03 Socket 022.906.233.B You will also need the wire ends but I'm not sure which ones those are. If anyone has a picture of one, I can look it up. There are pictures of all electrical connectors at the end of the electrical section of PET if you want to look at yours and compare them to the pictures. Of course a local salvage yard may have a set of leads with them on there...not sure. |
Thanks RB
I have looked through boneyards and not had much luck. These connectors are getting on 20 years old now and the plastic is really brittle. I will try 2 post pics later. |
| All times are GMT -8. The time now is 07:07 AM. |
