Passenger side front seat belt
I am looking for a Passenger side seat belt part. It's the part that the seat belt plugs into. Mine will not hold the seat belt in place. Also my emergency brake will pull up but it wont stay up. If anyone has these parts I would like to purchase them. Thanks!
Dave 1984 944 N/A Black (Daily Driver.) New Users please add your car's year and model to your signature line! |
Redline Racer
You might be able to fix the e-brake handle. Remove it from the car and check the ratchet pawl. You might be able to reshape it with a file and it'll be as good as new. Same prob with mine and that fixed it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Or just flip the pawl back over and get it to fit into the hook in the end of the push button rod. When the parking brake handle comes up past where the pawl can engage the teeth on the "gear" it flips over out of the hook at the end of the rod. By pulling the handle all the way up and using a slim long screw driver to reach under the handle you can flip the pawl up and catch the hook as you press the button in. Seems a bit of a challenge when you first try. Once the pawl engages the hook keep the button pressed in and lower the handle all the way down. Now jack up the rear and take off the wheels because you need to adjust the parking brakes through a hole in the disk brake hub.
If the handle still wants to come up too far then you have to adjust the cable under the carpet by the handle assembly. Don't adjust the cable first!
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
