Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Question 944S2 - Thermo-Fan-Switch ?
Help!
I wrote earlier that the cooling fans on my 1989 944S2 were running constantly - ran down the battery overnight.
I ordered a new thermo-fan switch from pelican (overnight for big $$$). It arrived today - and I don't know what I have - or what I need.
The switch I took out is 19mm across the flats - the one Pelican sent is 30mm across the flats. My old one has 2 contacts - the new one has 3.
The switch I took out is Bosch # 0280130026. Thee is only 85 degrees on the new one.
Here is where the switch I took out (hole) is located on my 1989 944S2:
http://www.naturephotostudio.com/944S2/Engine-Top.jpg
Here is the old switch in the engine:
http://www.naturephotostudio.com/944S2/Old-In-Place.jpg
Here is the old and new plug side by side:
http://www.naturephotostudio.com/944S2/Old-New-Side.jpg
And, here are the connection for the old and the new switch:
http://www.naturephotostudio.com/944S2/Old-new-Plug.jpg
Am I in the wrong place with the wrong switch???
If the 30mm switch is correct - Where does it go??
I can get a new Bosch # 0280130026 at a local parts store today. But - it is getting close to Miller time on a Friday and I want to do this job this weekend.
Any help????
Where is the thermo-fan switch on a 1989 944S2 (not 944 or 944S -but S2).
Dick
Old 02-23-2007, 12:21 PM
bearone2's Avatar
big $$$$, they're about $18 and are hi or lo temp, the lower being a few $$more.
it's a 30mm, some 1 1/8 will work. i used a deep socket and had the car on ramps and didn't take the radiator out.
same place as all of them. upper left part of the radiator.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 02-23-2007, 12:28 PM
ae1969's Avatar
Send a message via ICQ to ae1969
You have the dme temp sensor (blue plug)
the thermo fan switch is on the radiator itself............
hehehehe
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 02-23-2007, 12:31 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
like AE said, the one in the BLOCK is the DME temp sensor, has nothing to do with your fans. the one in the rad, the 30mm one, is the one that operates the fans.
1995 993 C2
Old 02-23-2007, 12:35 PM
Thanks to all. I was in the wrong place.
And - that is WHY I asked.
The big $$$$ was for the Fed Ex - the part was cheap.
And now to find the real switch - and a 30mm deep socket..
Dick
Old 02-23-2007, 01:22 PM
Thanks to all, again.
OK, I found the thermo-fan switch - down below the hose - right on the radiator. Man - that will be hard to get to. The DME sensor was out in the open and right on top.
What shoudl I take off to make the job a little easier? Air intake box??
I'm pretty good at working on my 356C - but the 944S2 is nothing but wires and hoses. I wish my town had a Porsche dealer. My car is dead and the closest one is over an hour away by interstate.
On the other hand - I do enjoy working on the cars, and I will enjoy the 944 learning process.
I bought the entire 944 factory manual set, but it seems to be lacking a lot of S2 information.
Dick
Old 02-23-2007, 01:44 PM
OK - the answer seems to be - do it from below. Thanks to the Clarks Garage site.
I'll try that in the morning.
http://www.clarks-garage.com/shop-manual/cool-05.htm
Dick
Old 02-23-2007, 02:48 PM
gtroth's Avatar
I took the fan assembly out, made it alot easier and was easy to remove.
1995 993C4 guards red
1988 944S alpine white
Old 02-23-2007, 06:11 PM
Easier to do it from above.
Take out the AFM and you will have enough space.
1993 964 C2 still makes me smile
1996 318ti (280k miles)
2011 Silverado for hauling (32k miles) - SOLD
2018 Suburban Z71
Old 02-24-2007, 02:17 AM
OK. The job is done and my fans are back under control. Pelican did send the right part. Thanks to them.
I did the thermo-fan switch repalcement from below. The deep 1 1/8 inch socket made the job easy after taking off my tray. I used my Craftsman 1/2 inch torque meter to tighten it up to 20 nm. The hardest part was waiting to get all the air out of the bleeder.
Many thanks to all who helped - and to those who taught me about the DME temeperature sensor!
Dick
Old 02-25-2007, 03:18 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
