my window ate my homework
I changed out my passenger mirror assembly. I made but splices. (A real pain to do by yourself)
I rolled down and back up the window. It ate my wires and pushed them out the window track. ARRRGGG My question. I can't remember can I access them from the inside via the removal of the door panel? What advice do you guys have to prevent this wire eating again.? Thanks |
You will have much more room to work by taking the door panel off. Relativley easy to do also.
There is a little metal piece that comes off the window track which allows you to route the wire harness and keep it away from the window. Its a strap that bends easily so you can wrap it around the window frame. With the door off, i would simply get creative with zip ties. With the panel off you can easily run the window up and down a few times to check clearances. I feel your pain, replaced the doors on my friends '89 and had to resplice a bunch of wires back together. I highly recommend buying this tool... http://www.radioshack.com/product/index.jsp?productId=2062786&cp=2032058.2032236.203 2310&parentPage=family This will make your life and splicing wires about 100x easier. I replaced the wire harness on a '85 944 and without this tool, i would probably still be splicing wires. I admit i took the easy way out with my car, i never redid the wiring to mate up with the 968 mirrors. Once in a while it would be nice to have the defrost option, but that is usually once a month. |
