timing belt cover issue
I replaced seals, gaskets, belts, water pump and other required parts along with rebuilding balance shafts. I set the timing belt at 40lb and balance belt at 28lb. I removed the cover to recheck and adjust belts after about 2500 miles and noticed that the timing belt is rubbing the inner cover and has worn a small groove in it. Doesn't seem like it is getting any worse now and there is no apparent damage to the belt. Does anyone know why this may have happened. the cover was installed properly along with everything else as far as I can tell. Thanks for any help.
Todd
Todd Staples
Old 02-27-2007, 06:03 AM
Graduated User
conkeytonk's Avatar
Hey Todd,
My cover broke at the rear connections to the block and was essentially floating. I am in the process of replacing it with a good used one.
Randy
1977 Scirocco Rebuilt 1.7L Stock Grey (Totaled)
1979 Scirocco Built 2.0L Stroaker Blue (Pilfered)
1979 Scirocco Built 1.8L Rust Bucket Tan (See ‘ya)
1982 Scirocco Rebuilt 1.7L Garage Kept Gold Daily Driver
1987 944 NA Rebuilding 2.5L One Female Owner Grey Weekender
Cruising to a conkeytonk in my Scirocco on steroids
Old 02-27-2007, 08:11 AM
SoCal Driver's Avatar
Check the flange on the timing belt tensioning pulley. Should be toward the engine.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 02-27-2007, 11:44 AM
thanks
I will check it out.
Todd
Todd Staples
Old 02-27-2007, 12:12 PM
