winter-hater club member
nynor's Avatar
removing exhaust manifold studs - tips?
i am about to remove the cylinder head from my car. as i recall from my '83, these studs are a PITA. any tips/ideas/tricks to getting these out, or getting the header off a different way?
i've already torn it down to the point where the cam tower is the next thing to come off. its much easier the second time around...
"COOL PRIUS!" - Nobody Ever
Old 03-02-2007, 07:18 AM
Greasy Member
many944s's Avatar
I just used a pair of jam nuts on the studs to back them out of the head. Worked well for me.
(This was on the '83 that I just sold)
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 03-02-2007, 07:41 AM
nynor's Avatar
so, thread other nuts on there, and back them out?
Old 03-02-2007, 07:44 AM
That Guy
Techno Duck's Avatar
Thread two nuts on, and spin the stud out with the first nut you put on. I did the same thing. My studs came out pretty easily, infact three of the studs came out with the original nut pretty much permanently corroded on.
Thats alot of nuts.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-02-2007, 08:01 AM
nynor's Avatar
excellent. on my '83, i gave up after about three studs and undid the exhaust system brackets. then just pulled the manifold over and wire tied it out of the way. it sucked. i don't think i will be able to do that with the turbo exhaust.
Old 03-02-2007, 08:18 AM
Send a message via AIM to Mike Markota
I was able to move the exhaust manifold over the studs (a small prybar helps) and install same way. Much easier
Old 03-02-2007, 11:46 AM
Proprietoristicly Refined
John_AZ's Avatar
This complete writeup is useful: http://members.rennlist.com/tom86951/headgasket.htm
John_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 03-02-2007, 05:35 PM
nynor's Avatar
thanks, john. that writeup is really good. the best i've seen, actually.
the very first problem listed describes something i noticed: at idle, the temp would get high, not really high, then immediately go down if i revved the engine.
i haven't noticed any coolant in the oil. there is nothing on the dipstick at all. there is a little condensation inside the oil filler tube, however. also, i haven't seen any oil in the coolant. so i am hoping i am okay there.
Old 03-03-2007, 06:28 AM
ae1969's Avatar
Send a message via ICQ to ae1969
The headers come out with the head.......... Then you can do whatever you want to them.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-03-2007, 05:53 PM
