67l60's Avatar
cat is in warning light is on !!!!!
ok i just had the cat installed
after not haveing one for who knows how long and the dang check engine light is on now
any one ever have this problem the ! is on
1986 944 n/a hard top, black on burgundy
Old 03-04-2007, 07:23 PM
Eldorado's Avatar
has your idle dropped at all?
the added obstruction in your exhaust system may have caused your idle to drop a bit... causing the light to come on..
it's completely normal, as long as it goes off when the gas pedal is pressed. if you dont want it to come on, you can try "fixing" it by increasing the idle a wee bit.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-04-2007, 07:54 PM
67l60's Avatar
light stays on at all rpms
but it does seem to idle differently
Old 03-04-2007, 08:01 PM
67l60's Avatar
actually smoother and still idles at 900
Old 03-04-2007, 08:04 PM
Eldorado's Avatar
then i'm not too sure.....
Kyle
Old 03-04-2007, 08:24 PM
67l60's Avatar
its not really brite like when switch is in on position but its on rather dim butt still on all fluids check out
Old 03-04-2007, 08:32 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Since when does low idle trigger the light?
Low oil pressure, low voltage or a few other items that are BYPRODUCTS of extremely low idle might trigger the light, but low idle itself shouldn't.
My 951 idles like crap when cold (about 300-400 RPM regardless of what I do to fix it) and I don't get the "!" light.
Black Cars Matter
Old 03-04-2007, 10:52 PM
There is no check engine light, per se, on an 86 944.
There is a ! light, but that is to call attention to another warning light, like the brake warning light or the low fuel light.
Is there another light on besides the ! light?
When you turn on the ignition (before starting) do all the warning lights illuminate? If not, you may have a warning light that is burned out.
Good luck, George Beuselinck
Old 03-05-2007, 03:26 AM
67l60's Avatar
thanks for the replies
and to answre some more questions
all lites do lite up with the igniton , in on pos . and no others are
on while running except ! and its very dim
Old 03-05-2007, 06:06 AM
Not supposed to work that way. The ! light only comes on when another light is on.
Sounds like you have an electrical problem in your gauge cluster.
Old 03-05-2007, 06:12 AM
67l60's Avatar
well my dome light, does keep popping fuses .
so i guess thats not to far to jump . they the two electrical probleems seemed to start at about the same point, right after picking up from the muffler shop .
where as prior to being there i had none,butt they couldnt possibly mess up wireing while doing a cat
so logic has ruled them to not be at fault ,
butt rather its just being grumpy .about have its tail pipe corked.
and i have to yet again show it whos boss
id swear this car hates me
Old 03-05-2007, 06:24 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Is your emergency brake handle down all the way. If it's only one click up, then that light will come on.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-05-2007, 09:16 AM
67l60's Avatar
thanks
i was looking at that the ebrake as it is needing new pads
so adjustment is way off i disconected the elec wire at the handle for its switch and its still on so i figured this couldnt be the problem , was i wrong ?
i dont have a brake light warning on
even though i will be doing brakes very shortly , and going thru the sys ,new fluid and all its pretty brown
Old 03-05-2007, 09:27 AM
Just thinking out loud
mattdavis11's Avatar
He meant on the handle. The wire you disconnected will not allow the E-brake light to go off if it unplugged.
91 FJ80
84 Ram Charger (now gone)
Old 03-05-2007, 05:14 PM
67l60's Avatar
i forgot to say i plugged it back in
thanks i was just checking it out
if that right it could still be the switch then
Old 03-05-2007, 05:26 PM
The instrument cluster brake light will not come on because of the handle...only the middle warning light. It may not be the problem. I just did that one time and couldn't figure out why the warning light was on.
Tom
Old 03-05-2007, 09:21 PM
Eldorado's Avatar
could a problem with the o2 sensor do that? like.. if it was disconnected?
just throwing that out there...
Kyle
Old 03-05-2007, 09:41 PM
No, disconnecting the O2 sensor or having a bad one will simply trip the DME into running in open loop mode. Euro cars have no O2 sensor.
Black Cars Matter
Old 03-06-2007, 02:01 AM
