Throttle Cam
I am new to this board. Just starting to learn.
I bought an 89, 944 with 67,000 miles on it.
Took it to a shop to get checked out and they could find nothing wrong with it. Replaced all drive belts and tensioners.
Here is my question: I added a Throttle cam. (let me just say WOW. get one if you don't have one.) But now I get more of a drop in the RPMs when I let off the gas, like to break. It did not seem to do this before with stock cam. Is this correct? Is the drop because the throttle closes quicker and the system has to recover? Is this the way it should work? I am going to put back on the stock cam just to double check. Any experience on this?
89 944 Owner
Loving it when it works.
Praying it don't break.
Old 03-06-2007, 11:14 AM
Eldorado's Avatar
your theory sounds about right... the old cam is made to open/close slower than if it was a perfect circle... if you're chopping the accelerator off, you're giving the engine and fuel delivery system even less time to re-engage... thus causing your engine to have a lower idle for a split second..
I'm no expert, but that makes sense to me.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 03-06-2007, 02:27 PM
Agree with Eldorado.
Maybe try cleannig your Idle control Stabilier (under Intake Manifold to Throttle Body) Try using Brake Cleaner in side it or such. Also new 02 sensor might help for faster adjustments.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 03-06-2007, 09:39 PM
Dave101's Avatar
Send a message via Yahoo to Dave101
So how hard was it to put the new throttle cam on and how much did it cost to buy one?
Dave
1984 944 N/A Black (Daily Driver.)
New Users please add your car's year and model to your signature line!
Old 03-07-2007, 06:44 AM
jezza944's Avatar
Search this forum "Throttle response cam mod" and it'll tell you how its done FREE!
Magickingdom, it sounds like your cable is a little tight. With your engine off, touch the pedal and there should be a little "click" from the cam.
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 03-07-2007, 02:43 PM
To Dave101:
You can buy it online at any Porsche parts location.
It took about 5 minutes to install.
It does not change your horsepower, but it changes your throttle response. And let me say, it works great. You think that you have more horse power. It really helps with the acceleration.
Sweet little $35 part. Get one you won't regret it.
89 944 Owner
Old 03-08-2007, 10:07 AM
Dave101's Avatar
Sweet. I am gonna have to get one of those then. Now my next question is: I see a lot of chips for new 944 but none for my 1984 one. Like this link here would be cool. http://cgi.ebay.com/ebaymotors/Porsche-944-968-Performance-Speed-Chip-Module_W0QQitemZ220089281363QQcategoryZ33597QQssPa geNameZWDVWQQrdZ1QQcmdZViewItem
I liek the idea of beign able to turn it off if you want.
Dave
Old 03-08-2007, 10:44 AM
Dave101's Avatar
or thsi one maybe?
http://cgi.ebay.com/ebaymotors/22-HP-Progressive-Tuner-PORSCHE-944_W0QQitemZ7972961075QQcategoryZ33597QQrdZ1QQssP ageNameZWD1VQQcmdZViewItem
Or are some of these just junk that can mess up my engine?
Dave
Old 03-08-2007, 10:49 AM
Dave101 -- There is a guy named Russell Berry who is working on a solution called the maxtronic. I beleive support for the early boards is almost finished.
Check out his site here -> http://www.maxhpkit.com
The other option you have is there used to be a guy named FR Wilk who would modify your ECU to allow for chipping. Rumor has it he's back. Use him at your own risk.
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 03-08-2007, 11:10 AM
Dave101's Avatar
any idea as to how much HP this adds? Does it kill your gas milage? Does anyone here use one of the Wilk chip? If so do you like it? Thanks!
Dave
Old 03-08-2007, 11:22 AM
