callmethewander's Avatar
bumper pad fix
just came up with an easy fix for a loose bumper pad. instead of goop or epoxy or even a threaded stud. i took a 1-1/4 in lag bolt and screwed it into the bumper pad through the hole on the bumper with a washer on it. i predrilled the pad a little so i could get the bolt started, it worked great and is holding solid. You must be careful not to use too long a lag-bolt and pop through the bumper pad.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-12-2007, 05:23 PM
