-   -   hatch question: are all 944s 100% same? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/335080-hatch-question-all-944s-100-same.html)
thoen 03-11-2007 05:49 PM
I have a spoiler that isn't quite 100% fit on my 1983. Are all of the hatch glass curves exactly the same or are later models slightly different from the earlier ones?
Porsche-O-Phile 03-11-2007 10:33 PM
Pretty sure they're all the same. I've seen early and late hatches used interchangeably, as well as the ones from a 944 onto a 924S (although the spoiler itself is smaller). 968 hatches also fit fine AFAIK.
thoen 03-12-2007 05:24 AM
i was wondering about the curvature of the glass. i bought a rear spoiler from england and the fitting is about 95% and 5% off base. i tried in everyway to lay it flat but it just doesnt make it down 100%. if the curvature changed slightly, lets say in 1985.5 then i can fix this. if not, i will have to work around it to with fiberglass at the points that don't tounch. thanks!!!
AaronM 03-12-2007 05:26 PM
They're all the same. Can fit any OE spoiler on any of the hatches. Aftermarket spoilers, even ones supposedly made to original specs, may suffer build-quality issues that cause problems with fitting them though.
thoen 03-12-2007 05:30 PM
thanks aaron!
