callmethewander's Avatar
transaxle rattle?
i thought is was my exhaust, but i have a definite rattle coming from the rear transaxle, it stops when i disengage the clutch, any ideas? it's an '88 944S. i also smelled gas several times on my drive today, where should i look?
thx, jc
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-14-2007, 01:36 PM
SoCal Driver's Avatar
If someone installed any speakers or other items in the cargo area and drilled holes through the bed then the gas tank has the same holes in it. If not the gas tanks have a tendency to crack on the top along some structural folds.
Also check your fuel rail fittings and hoses.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-14-2007, 01:43 PM
Politically Incorrect
onZedge's Avatar
...and the vapor canister and hose...
Edek
'87 924S
'91 535i
Old 03-14-2007, 01:48 PM
thanks, any idea about the tranny noise?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-14-2007, 01:50 PM
sasquatch's Avatar
Normal. They get noisy in neutral with the clutch out as they age. Every 924/944 based car I had did this.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 03-14-2007, 02:54 PM
onZedge's Avatar
Tranny noise could also be a bad torque tube bearing, loose union between the drveshaft and transaxle, loose exhaust component. I have the same symptoms with mine. Started right after I had the clutch replaced. Loose muffler heat shield was a BIG rattle. Now I just have the little rattle exactly as you describe.
Edek
'87 924S
'91 535i
Old 03-14-2007, 03:29 PM
yes, but was it in neutral with the engine idleing only with the clutch engaged, there's only 78,000 mis. on the car! it seems something must be wrong or worn to make noise like that.
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-14-2007, 04:54 PM
EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
ive started a thread about this, and discussed this in some pretty lengthy detail over at rennlist.
My tranny, "rattles" like yours, its a high pitched squeaky rattle that shows up once the drive train has been warmed up, and while the car is sitting idle in neutral. once the clutch is fully depressed the noise goes away.
I have an extra TT in the basement that i may rebuild and install once my car needs a clutch until then it will sit down there.
another theory i read over at Rennlist was that it could be 'the fifth gear' rattling. not sure what that is.
1995 993 C2
Old 03-14-2007, 06:40 PM
Parrothead member
VINMAN's Avatar
Check your lube level in the tranny.
Vinny
Old 03-14-2007, 07:02 PM
will do Vinny, thx, Kevin and all i'll go look for that thread
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-14-2007, 07:49 PM
