-   -   which way does it turn (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/335717-way-does-turn.html)
tnporsche 03-14-2007 08:46 PM
On the elec sunroof the nut that adjusts the tension. I know you can turn it to remove the sunroof manually. ( I never have been able to get it to work normally, another story )
So I don't put too much pressure on the little gears; to raise is it turned clockwise or counter clockwise???? ( I can't remember )
Gremlin85 03-15-2007 07:31 AM
manually opening the sunroof with a 21mm(???) is counter-clockwise.... atleast mine opened when I was feeding the cable back up when it was laying in the trunk.
