Broken tensioner stud.... HELP!!!!!!
86 951. Tensioner stud had broken off at the threads on the block end. Anyone have any experience getting one out!!!
86 944 daughters 88 944 step-sons 07 Ranger 4x4 I have tons of spare parts, let me know what you need. |
winter-hater club member
use an easy out? are there ANY threads sticking out?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Uhmmm there is a nut that should be flush with the block......
How did you bust that? It depends how much is showing. Heat is your friend....
Alex - PCA Polar Region - Boxster Muncher 86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD www.edmontonhomelife.com www.edmontonrealestate.ws |
it broke right past the nut. In other words.....I pulled the front part of the stud out with the tensioner, locking nut on front, and the back nut that is flush with the block, plus the shaft of the tensioner. It broke right at the threads on the block side.
oh boy...
YEP!!!!
If the engine is still in...........
You will need...... Patience, left hand drill bit, heat .......... repeat Worst case scenario you drill it out and re-thread. Not as bad as it first seems.
Burn the fire.
EDM...
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
Greasy Member
I had the same thing happen on a friends 951...
All I can tell you is, you need alot of patience, a drill bit, an "easy out" and a steady hand! good luck! -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
hi todd,
did you find the hatches? i sent a pm. thanks!!!
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Cars & Coffee Killer
I'd recommend an "easy out" over a left-handed drill bit.
An "easy out" (at least the one I have) is tapered and reverse-threaded, so it will really grab the broken stud.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Can you post a picture. Not quite sure if anything is sticking out. Mine was the same when I got it. Once I took the tensioner assembly off the block, there was enough to grab with a wise grip and it came right out.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
I agree with Alex. I would start with a left handed drill bit to drill a hole in the middle of the bolt. I would file it flat first (if enough of the bolt is still there and if not use a center punch that is the same size as the hole to mark the bolt center. Then drill with a left handed bit and it may grab it enough to back it out. If not, then stick the ezout in the hole and back the bolt out. Make sure you don't break the ezout...then you are in real trouble.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
It is broken off just a little below the surface of the block. But....it is a clean break. Going to Sears to get a left hand drill bit.
I've never seen a left hand drill bit. Why would you need one. A hole is a hole.
The most important thing I find is to get it perfectly centred and straight. I have never had any luck with easy outs. After much flustration, i find that i end up increasing the bit size till i get to the threads then fish out the little bit of remaining metle and run a tap through it. Use lots of heat and penitrating oil. The easy out may work???
TODD
PM SENT!
The beauty of a left hand drill bit.......... it wants to pull the bolt as it drills......that and some heat. WOrks everytime..........
And if not........ it drills it out anyways. Two possible outcomes with one procedure.....
Redline Racer
Oh man...I feel your pain but you've definitely got it worse. I had to drill out a stripped cam sprocket bolt, and I can assure you, I was thoroughly pissed beyond belief by the time I finally got it. Lots of patience needed is an understatement... (and lots of drill bits. Those things are too soft...untill you want to drill them out
)Is there even enough room to fit a drill in there? Maybe if you took the radiator out.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
PM SENT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
