My 944 is like a fountain
i put the 944 in the garage to replace the front brake rotors withcross drilled and new pads and sensors. its only sat in the garage for maybe 1 day and my garage floor has puddles of all different sizes all over the place.
i think i have to replace all the seals and gaskets, my question is, could there be any damagei should check for. and what seals and gaskets are priority? and what is the best way to go about buying them. thanks josh
1987 944 n/a
Old 03-29-2007, 05:39 PM
drift a 944's Avatar
do you mean for the engine?
see what types of fluids have leaked out onto the ground and go from there.
if it is oil, look around under the car and try your best to determine where the oil is leaking from. My car currently leaks from the oil pan gasket, but 6 months ago it leaked like crazy from all the front engine seals. You could replace ALL the seals if you wanted, but its really only necessary to replace the ones that are leaking, so its just a matter of determining where the oil is dripping from.
same goes with other fluids... power steering fluid, brake fluid, coolant, tranny fluid... even blinker fluid! j/k.
- Elliott Grafton - 944Barn
Old 03-29-2007, 08:22 PM
