-   -   Tips for installing FPR? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/338425-tips-installing-fpr.html)
CJFusco 03-29-2007 08:33 AM
I am in the process of installing a Lindsey 3.0bar fuel pressure regulator, but I am having trouble getting the base into the fuel rail. What is the best method for doing this?
nynor 03-29-2007 08:37 AM
you need a little injector 0-ring lube, or whatever its called. schmutz that all over the 0-ring and push it in.
CJFusco 03-29-2007 09:02 AM
Thanks, I got it.
At least I think I do - a little bit of the plastic grey ring is visible: is this normal? the FPR is flush with the mounting bracket and there are no gas leaks.
nynor 03-29-2007 11:14 AM
you are good. just keep an eye out for leaks. this is obvious, i know, but i am paranoid and check mine about once a week, along with the injectors, etc.
CJFusco 03-29-2007 11:18 AM
I am also paranoid and check for leaks, milkshake, oil level a couple times a week.
nynor 03-29-2007 11:25 AM
LOL! a brother!
CJFusco 03-29-2007 12:09 PM
Well, now that my 951 is my (temporary?) daily driver, I can't be too careful, IMHO.
nynor 03-29-2007 12:15 PM
oh, i hear ya. mine is my daily driver as well. until i get the new clutch in my '77 triumph bonneville, that is.
speedracing944 03-30-2007 03:04 AM
Anytime I touch anything fuel related I carry a fire extinguisher with me for a couple of weeks. I don't want her to torch up :(
Speedy:)
CJFusco 03-30-2007 07:07 AM
it's crossed my mind.
