badjones's Avatar
High mileage workout
Hey there. Seeing as the early 944's are really gettin old now I was wonderin how they are standing up to the years. Any high mileage examples still gettin driven daily and maybe driven hard still. Mine is, What punishment are they being dealt and how are they stackin up. You know, oil use, repairs necassary etc. This is maybe the way to define how truly good, or bad these things are without the glorious image of some of the more "sought after" models. What you reckon? Just a thought. Cheers from down here. B.J.
83 944. Guards Red
drive it like you stole it.... http://www.pelicanparts.com/gallery/badjones
Old 03-29-2007, 02:28 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
i'm not sure what you'd consider 'high mileage', but my '84 is getting close to 102k, my 951S has nearly 110k on it. there are many more around with higher mileage. these engines are fantastic! my 944 doesn't use any oil, it leaks a little (i know i know, one day i'll get around to it). i'm not sure about the 951S though, i haven't driven it much at all, since it's in need of a bit of work. hopefully i'll get around to it soon, so i can add more and more miles
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 03-29-2007, 07:33 AM
I meet a Porsche mechanic that just sold his 84 944 with 329K miles. I seen the car, looked in great shape. Of course it was well maintained.
Garold Shaffer
1973 914 2.7 /4 Flared Beast - SOLD
74 2.0 Daily Driver
74 LE Bumble Bee Project car
Old 03-29-2007, 07:44 AM
215k on the NA, and when I drive the twistys, I'm still never afraid to take it to redline.
Pulls hard (for an NA), reliable, bulletproof, I mean hell, I taught the girlfriend how to drive a stick in it.
Turbo has 193k, pulls insanely hard, just got done doing head work, the bottom end was just rebuilt, and I'm popping in a new tranny.
Runs great
I may have to sell them though
My cars for sale, due to move
1986 944 turbo - For sale.
1987 944 N/A - For sale.
Old 03-29-2007, 08:37 AM
My '87 944S has 275,000kms on it- it's on it's third or fourth
set of exhaust valves ---if you know what I mean. I only bent one set-- the PO bent the others.
Runs Great now, though--
Jeff
Jeff Laurence, '87 944S
Old 03-29-2007, 08:47 AM
winter-hater club member
nynor's Avatar
my '83 had over 150K when i traded it. ran strong, no leaks, did not burn oil.
"COOL PRIUS!" - Nobody Ever
Old 03-29-2007, 08:51 AM
I raced a 924S last year with 173K miles. Orig head, rest of motor gone through once 40K miles ago. Used about 1/2 quart of oil per race weekend. Ran strong, was bullet-proof in racing conditions. Steerling and brakes still tight. The rod bearing's need to redone once every 1-2 seasons depending on how much you race. The rest of the mechanicals are very stout. Keep up with the maint., and they'll run very well for a loooong time.
Old 03-29-2007, 12:56 PM
That Guy
Techno Duck's Avatar
Bought my 944 at 60k miles. Have done about 15 auto-x's with it and no real issues. 88k miles roughly the head gasket went. Other than its never left me stranded. Currently at 93k miles. Uses about a quart of oil every 3-3500 miles, depends how hard i am driving it.
Oil pan gasket is starting to get wet, but not dripping anywhere. Rod bearings and a front end reseal are on the list of to do's for August.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 03-29-2007, 01:07 PM
White and Nerdy
Tervuren's Avatar
On my '85 944, at the time of it being hit, the only problem it was a mild front end oil leak, and the shifter seal on the transaxel had gone bad. The AC system was rotted when my family originally got the car, also we replaced the master and slave clutch cylinders. Also I'd say it was time for CV replacement as well, but it got hit just before I was about to fix it all. Thankfully I'd waited, or else that would of been a big waste.
Shadilay.
Old 03-29-2007, 01:13 PM
callmethewander's Avatar
my '87 na has 119,+++ use it daily, regularly appraoch redline, corner fast love it and it runs great! my '88 944S only has 80,000 feels like a new car, seems to have been very well maintained, my '89 S2 has 117,+++ runs great handles great, but it does "consume' a bit of oil. none of them give me the feeling that there ready to bite the dust.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-29-2007, 02:26 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Newbies.
Theres 200K+ on my 944, almost 200K on my last 951 (never had any engine work and still had only 1psi difference across the cyls on a comp. test).
I have seen turbos and n/as at 350K+
120K miles is a baby.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 03-29-2007, 03:20 PM
badjones's Avatar
This is what I'm lookin for. I have no concerns about my NA lasting as it runs well for 120000miles, goes reasonably well and handles excellent. It is fantastic at eatin road at sustained high speed, 80, 90 mph and because of the handling can make up for steady accelleration by maintaining high corner speed. It does all this with excellent road feel and what I consider to be a high level of ( sports ) comfort. Mine will swallow oil fairly quickly when really gettin worked hard and seems to blow smoke above 4500RPM at full throttle but if driven conservitavely seems to hardly lose any. I just wanted you guys to express yourselves about these machines and compare their realistic virtues. Oil is cheap. I wonder if the ones that use "no" oil ever get flogged at full throttle, or maybe there is a marked difference in how these things are assembled and their machining tolerances. Come on, what about horror stories. Cheers. B.J.
83 944. Guards Red
Old 03-29-2007, 03:21 PM
sasquatch's Avatar
186,000 hard miles on my 87 na. It is regularly hillclimbed, auto crossed and driven hard in the twisties. Original motor. No leaks, does not burn oil, less than 3 psi variance in compression. Headers, FRwilk Chip, racing exhaust, full coilover suspension, and on top of that, a show winner.
Only failure ever was the stock differential went at 170k. Tons of hard auto cross launches probably did it in. Replaced it with a used S2 transmission and it is flawless again.
I have owned this car for the last 90,000 miles. By far the most reliable car I have ever owned. Yes, it is meticously cared for.
Sasquatch
1987 Porsche 944
1974 Porsche 914
"Don't retreat, reload." Sarah Palin
Old 03-29-2007, 03:39 PM
jay, what kind and grade of oil do you use? my '87 seems to burn the least when i'm running pennzoil 10w-40
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-29-2007, 07:15 PM
mechanically i think these cars are fantastic, it's the seats the dash and the sunroof that are troublesome, but that may be normal, the body, suspension and drive-train last so long that the regular stuff where's out, whadya think?
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-29-2007, 07:17 PM
Ornery Bastard
157,000+ on my 951. Runs great. The engines in these cars are incredibly solid.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 03-29-2007, 09:07 PM
meister member
speedracing944's Avatar
149,000 miles on my '83. She dynoed very healthy, runs great and has never left me stranded in 100,000 miles. She regularly sees redline and is flogged around on the twisties quite a bit. I do think it is time for some new suspension bushings though.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-30-2007, 03:00 AM
Parrothead member
VINMAN's Avatar
180,000. on my 86 Other than the 6 clutch master cylinders,Not one single problem, until my recent cooling issue. ( and hood latch problem.) Did a clutch change at 165k. Starting to burn some oil. I run it on 20w50. Dash started cracking last fall.
The 85 I had before this one. I bought at 143,00 the owner never did a belt change on it, I pulled it apart . the belts where in excellent condition a little loose but stil strong.
Vinny
Old 03-30-2007, 05:02 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
My motor had 200K and still pulled 134HP pn the dyno having never been pulled apart EVER.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 03-30-2007, 06:38 AM
sasquatch's Avatar
I run Shell Rotella T synthetic 5/40 in every car and motorcycle I own.
Can I advise you not to run Penz? I have torn multiple motors down that have used Penz and the were very carboned up in the valve train.
Sasquatch
1987 Porsche 944
1974 Porsche 914
Old 03-30-2007, 07:08 AM
