-   -   Trouble Codes? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/339285-trouble-codes.html)
Gremlin85 04-03-2007 11:10 AM
Trouble Codes?
Is there a way to get trouble codes from a 1987 944 NA? It has the Diag. Port so I am ASSuming that you can potentially hook up a scanner and get trouble codes and engine read-outs.
I know in GM cars with OBD1 you can bridge the connector pins and the check engine light will flash a number of times and pause a number of times giving you a trouble code to help diagnose problems.
Would this be true on the '87 Porsche? I know computer scan tools were not really used in the late 80's, not until 1990 did it really be used.
Just wondering...http://www.pelicanparts.com/support/smileys/yltype.gif
Razorback1980 04-03-2007 12:33 PM
Porsche made a specific diagnostic tool to attach to that port but the computer is not OBD compliant.
fast924S 04-03-2007 12:34 PM
I wonder if any one has a scanner that would work on it
SoCal Driver 04-03-2007 12:47 PM
Supposed to be a diode or be able to span two of the pins with a diode and read a blink code.
Gremlin85 04-03-2007 03:47 PM
Any site or list of these codes?
I wanna try out the diode and see if I can get anything from it.
ERAU944 04-03-2007 09:01 PM
i just read a panorama and/or post with information on this.
i'm thinking it was the last issue or the one before that... there was definitely an article in pano. check it out!
Gremlin85 04-04-2007 11:06 AM
I don;t have a subscription to the pano.
Is there a way someone could post the article?
P.S. TPS is fine, clicks and all... see last post of "Now I've done it..."
IAC?
