Bad Trans Mount???
Has anyone ever had a problem with their trans mount? It seems as if I'm getting some "wobbling" or "pushing" especially when I'm on the track from my rear. I'm trying to decide whether it's my trans mount or my tires. I checked the trans and it seems as if it has some play. If I bang it, with the palm of my hand, it'll move maybe 1/4" to the side and my muffler will hit the body. Has anyone else notice this? Can someone check and see if their trans has any play?
Also, are there any cons about using a solid trans mount (excessive wear on the trans, torque tube, cvs...). The car is a street/track car. It sees the track once a month. Thanks
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
The knee bone is connected to...
There is sufficient play in the CV's that any movement in the trans does not move the suspension. Check your trailing arm bushings.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
You mean these:
![]() I may have to go monoball??
How are the wheel bearings?
No play. First thing I checked.
