xupkid2's Avatar
Diagnostic Plug
I am in the middle of trying to adjust my idle and was looking on clarks garage. I have an 88 944 N/A and it says that there is a diagnostic plug that I need to jumper wires between to defeat the idle stablizer. The question I have is where the heck is theis diagnostic plug. The only diagnostic plug I know of is near the back of the engine but it only has 3 pins and hooks to a sensor near the flywheel. Anyone have any ideas? I know the car doesnt have a normal OBDII or but I wasnt aware of a diagnostic plug but assume it is near the DME or something.
If you need to see the clarks garage description check under Idle Speed Adjustment.
My hope is this may help solve another problem Im having because I adjusted the idle when I rebuilt the motor but never jumpered the wire.
Brian
1989 944 Turbo Cup Replica
PCA Space Coast Region #44
Old 04-18-2007, 07:15 PM
That Guy
Techno Duck's Avatar
The connector is right infront of the firewall on the drivers side of the car, right behind the strut tower. Its kind of recessed with the emissions control stuff running around it. There is a black cover that you need to pop off to see the actual connector.
Circled in the picture.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-18-2007, 07:17 PM
xupkid2's Avatar
Thanks much. I found it. Never knew it was there.
Old 04-18-2007, 07:22 PM
Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Took me a week to find it.
Turns out the PO had put a special voltage regulator adjuster thing right on top of it. I thoutght the voltage regulator was just part of the factory harness and was never the wiser...
I found it though... I found it.
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 04-18-2007, 08:17 PM
