Jerome Ryals's Avatar
Fuel filter fittings
Will these female fittings on both ends of this fuel filter unscrew?
It is mounted on a '80 931 (924 turbo)
Old 04-11-2007, 01:08 PM
callmethewander's Avatar
i couldn't get mine off, but usually you would put one wrench on the brass colored fitting to keep it from turning and another wrench on the smaller dark fitting and turn that one to remove the filter.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 04-11-2007, 03:41 PM
i just sprayed mine up with PB blaster and i'm letting it soak in for a couple months, or until the weather is nicer
1989 S2
1988 S
1987 944 n/a (sold)
Old 04-11-2007, 03:42 PM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
Use flare nut wrenches, and if the fittings are tight, clamp vice-grips over the ends of the wrenches to keep them from spreading apart (and rounding off the nuts.)
good luck
nate
1988 944... and a bunch of other cars
Old 04-11-2007, 03:45 PM
I've taken the filter off before, it was installed backwards but my new filter does not have the 'brass colored' female fittings on both ends, just one. I guess I'll find out this weekend.
Old 04-11-2007, 05:27 PM
Could I push in here and ask if the fuel line needs depressurizing before removing this filter?
944s2
Old 04-12-2007, 01:09 PM
winter-hater club member
nynor's Avatar
it does. unless you want even more fuel to come gushing out.
"COOL PRIUS!" - Nobody Ever
Old 04-12-2007, 01:15 PM
ok, thx
1989 S2
1988 S
1987 944 n/a (sold)
Old 04-12-2007, 01:18 PM
The brass female fittings on the filter will unscrew if that is your question. I had to change them on the 924S when the new fiilter came thru with the wrong ends.
Hope this helps.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 04-12-2007, 05:09 PM
Thanks Jon, thats what I needed to know. Same situation here.
Old 04-13-2007, 02:55 AM
