Key Head Replacement
Bought a new lighted key head replacement, but I'm not sure how to remove the key from the old head. I thought it would just pull out. It's seems to be in the old head pretty tight. Is there a trick to getting it out, or do I just pull harder?
'83 944
'87 951
Old 04-14-2007, 09:38 AM
LOL I have the same problem, except I bought a new blank and cant figure out how to get it in the key head.
Where in FFX Station are you? Dont see too many 944s round these parts.
edit- well I just got the blank in. Did you try taking it apart to see if you could get it out? The blank goes in at an angle and then you pivot it to lock it.
Jason
88 924S SE
Old 04-14-2007, 05:21 PM
I'm about a mile off 123. You don't see many 944's around here. I lost my 83 in a fire and have a 968 now - guess I need to update my signature line. I took the cover of the key head where the battery goes, but that didn't help me much. I tried to pull it out an an angle too. I can see where it would clink inot the neew head so I tried taking it out at the "right" angle from the old head, but no luck. Might need a bigger pair of plies. I need to be careful, this is my only key!
'83 944
'87 951
Old 04-15-2007, 12:47 PM
This is how mine comes apart. Pop cover off using a small flat screwdriver on the side with the indentation.
Remove button and battery
Remove the very small piece of plastic to the outside of the spring. 1/8" sqaure
Remove the spring and larger piece of plastic
Now the key is unlocked and will come off the head
Don't loose any pieces!
Stephen Fraser
Poland Spring, ME
1986 Guards Red 944NA
Old 04-15-2007, 03:11 PM
callmethewander's Avatar
yes, be careful, there is a spring under the battery and one in the slot of the piece that holds the key in place.
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 04-16-2007, 07:12 PM
