monsterdog's Avatar
upper radiator hose getting chewed by fan
Has anyone had this issue? Upper radiator hose sprung a leak, after pulling it out discovered driver-side electric fan blades had been working on it over time. Was on the underside so I didn't notice until it was too late.
This is the driver side hose (larger) to the cooling water tube which mounts on the front of the block and terminates at the bleeder fitting on the cylinder head. Clearance is really tight down there, and the hose itself is smushed inbetween the twin-fan housing and the metal cooling-water branched crossover pipe which interconnects the turbo water pump to the secondary thermostat and other side of the radiator.
Could I use zip ties to secure this hose as far up as possible to the water tube and allow for as much clearance as possible from the fan blades? Or would that just cut into the hose over time as well?
Seems strange that the path of the hose would be designed this way, so close to the fan blades and all.
1986 944 Turbo, 88k miles, Copenhagen Blue
Old 04-23-2007, 05:42 PM
Redline Racer
HondaDustR's Avatar
Re: upper radiator hose getting chewed by fan
Apparently, this part of these cars must have been desinged on a monday, or something....
I don't know about the turbo, but on a N/A, the hose is very close to the alternator pulley and will buzz through it if you don't mount he hose and radiator just right.
It could be that your car doesn't have the right hose. When mine got buzzed through by the alternator (was actually an installation error on my part), I found that the part number was not the same as what my car called for.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 04-23-2007, 06:27 PM
Greasy Member
many944s's Avatar
Hmmm, my '85 n/a has a clamp that mounts around the upper hose and holds it out of the way of impact from any moving parts...
fwiw
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 04-23-2007, 06:38 PM
fast924S's Avatar
Send a message via AIM to fast924S
Try flipping the hose around, I had the same problem on my 924S, Got a new hose and installed it the other way around and it worked fine.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 04-23-2007, 06:44 PM
Send a message via AIM to MPitt
If you're having the same problem I was, I just shortened the hose by an inch or two and it fits fine and not in any danger now.
Edit: Sorry for the necro post. It's late and I'm reading a couple pages back...
1984 Porsche 944
1986 Porsche 944 Turbo
Old 04-26-2007, 07:46 PM
