1978 924 fuel tank
The Chilton Manual tells me that I need to remove the transmission before removing the fuel tank. Is this necessary or is there a trick
thanks in advance for your help |
Could just cut the floor out of the cargo area.
Then maybe not. Remove the trans.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
