winter-hater club member
nynor's Avatar
what tires are people running on their
15" stock wheels, again for 85.5?
"COOL PRIUS!" - Nobody Ever
Old 04-25-2007, 11:05 AM
Re: what tires are people running on their
225-50-15
Falken ZE-512 -Good Value
Yokohama ES100 -middle
TOYO Proxes T1-R - down side, Pricy
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 04-25-2007, 11:29 AM
Parrothead member
VINMAN's Avatar
BF Goodrich touring T/As
Vinny
Old 04-25-2007, 11:37 AM
nynor's Avatar
are the 225's wide for those wheels?
and vinny, you link on you sig is broken... i was curious and tried it.
Old 04-25-2007, 01:20 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
I had been running Toyo Proxes T4-S.
They are cheap, and stick well.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 04-25-2007, 02:11 PM
ilikemy944's Avatar
Oh yea - and they were 225/50-15 also.
Brad Tompkins
Old 04-25-2007, 02:13 PM
@ 3 digits
rayporsche's Avatar
225/45-17 up front and 255/40-17 in the rear, Yokos AVS-100 which stick pretty good but can go faster than a bottle of 'Glen' on a friday night., probably the treadwear....
'Enjoy the little things in life, for one day you will look back and realize they were the big things'
Old 04-25-2007, 03:29 PM
nynor's Avatar
apparently, you missed the original post 15" STOCK wheels for an 85.5
Old 04-25-2007, 03:52 PM
@ 3 digits
rayporsche's Avatar
Apparently !!! I would say way obviously, no wonder i was kinda of wondering about the 15's., Please accept my apology and don't worry I'll crawl back to my hole. Thanks.....
Old 04-25-2007, 04:34 PM
Custom User Title
Dave L's Avatar
225/50/15 RA1's
Old 04-25-2007, 05:10 PM
nynor's Avatar
don't crawl anywhere. welcome to the board, missed that it was your first post. you oughta make a new post with pictures and such of your ride.
Old 04-25-2007, 05:18 PM
nynor's Avatar
it seems that the consensus is 225/50/15. i'll pass that along and thanks everyone for their posts!
Old 04-25-2007, 05:24 PM
74goldtarga's Avatar
Nynor, if your wheels are 15 x 7 I would go with 225, if 15 x 6 I would consider 205. 205s are already pretty wide on a 6 inch wheel, that is what I had on my 911 Fuch wheels. Tech specs for Toyo performance tires put a rim width of 6in as minimum for 225, you'd rather be close to maximum rim width for the tire, less slop as the sidewalls move during cornering. Contact patch size is a function of tire loading and inflation pressure, not necessarily tire size (bigger isn't always better - but it usually costs more).
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 04-25-2007, 07:51 PM
White and Nerdy
Tervuren's Avatar
I prefer the tighter wrapped 205's to 225's on the front. On the rear, I am going to work a lot more heat into those tires, and having more rubber to distribute the load can help if I'm pushing for a long time.
Shadilay.
Old 04-25-2007, 07:55 PM
pdx944's Avatar
On an NA anything over 215 is too much tire for the car.
Old 04-25-2007, 08:02 PM
nynor's Avatar
do you care to expound on that? there are several posters above that are running 225's. just curious as to your take on this.
Old 04-25-2007, 08:09 PM
Non Compos Mentis
I race my 944. My class limits wheel width to 7", so we all run 225 Hoosiers. 225s on a 7" wheel are pinched a bit more than optimal, but still allows for better cornering forces, a worthy compromise.
A 944 is most fun to drive with equal sized tires front/rear. I have a set of 225/255 17s that are used just to get the car on and off the trailer. The car looks great with the wide 255s in the rear, but it understeers like a pig.
The later cars came from the factory with 205/225 and 225/245 setups to induce understeer. That's considered safer for the average (poor) driver. All the serious 944 autocrossers around here use 225/225 on the NAs, and 245/245 on the S2 and turbos.
Equal tires allow the tail to beautifully drift in complete control.
Old 04-25-2007, 08:34 PM
Dantilla, you are talking 225 on 17 x 7. Wouldn't you argue that 225 is a bit wide for 15 x 6? When people run 245 front/rear are they using 8" rims on the front? I am taking my car to the track Friday with 225/245 16s on 7"/8" rims - I still qualify as a poor driver but hope to be over that by Monday. You're making me think I should get some 16 x 8 for the front and run 245/245.
Old 04-25-2007, 09:44 PM
Non Compos Mentis
225/245 on 7&8" will be fine.
Learn to drive the car. Any car. What you learn on the track will make you a better driver no matter what you drive.
225/245 is a factory setup. Can't complain about 944 handling at factory specs!
We have a very competitive autocross program, with several drivers with national titles. Every little bit makes a big difference. But what you've got will work just great. When you need an additional .002 seconds over your competition, then we can look at fine-tuning the details.
Have fun.
And you're correct, a 225 tire will not work properly on a 6" rim.
Old 04-26-2007, 06:54 AM
Aslet's Avatar
What would be a good tire if I want to stay at the stock 215/60-15 size? I have been looking at the Bridgestone Pole Position ultra-high performance all-season tires... I have a set of good snow tires, so I just need summer tires, but these seamed to be the better compared to the Dunlop or Pirelli tires still for road use in the dry and wet... Any suggestions?
Randy
'84 944
Old 04-27-2007, 05:34 PM
