Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
944 Clutch Problems
Hey guys...My car has been sitting in the garage for a couple months... 3 days ago I decided to take it out and wash it! So I did, I didn't get to drive it around that day say I parked it back in the garage.
well....Now the clutch won't even work! Everytime I push in the clutch, its like its not even engaging in. I can't get the car to go into any gear. The clutch was working fine 3 days ago when I pulled it out of the garage. My brake fluid level is fine....and I haven't had any clutch problems before! Any ideas??
1986 944 non-turbo
Old 04-28-2007, 08:01 AM
winter-hater club member
nynor's Avatar
are you saying that the clutch doesn't release?
"COOL PRIUS!" - Nobody Ever
Old 04-28-2007, 08:33 AM
correct....when I press the clutch in, it will not let me go into any gear while the car is running!!! If I try to force it into a gear....the car starts to roll slightly.....as if i'm not even pressing the clutch in!!!
1986 944 non-turbo
Old 04-28-2007, 08:39 AM
nynor's Avatar
interesting. how much resistance is against the pedal when you press it? is is possible that the slave has come loose?
Old 04-28-2007, 09:05 AM
the same amount of resistance that is there during normal operation!!! I couldn't tell anything by just pressing in the pedal...the only way I could tell was when the car refused to go into gear!
1986 944 non-turbo
Old 04-28-2007, 09:08 AM
nynor's Avatar
hmm... is it the original clutch?
Old 04-28-2007, 09:16 AM
I just bought the car about 2 1/2 years ago and the previous owner claims the clutch is fairly new....I have not had any slippage or any signs of clutch issues!
1986 944 non-turbo
Old 04-28-2007, 09:22 AM
nynor's Avatar
does it return normally?
Old 04-28-2007, 09:38 AM
yes
1986 944 non-turbo
Old 04-28-2007, 09:42 AM
nynor's Avatar
wow. i am at a loss. someone else will probably chime in.
Old 04-28-2007, 09:49 AM
thanks man!!!
1986 944 non-turbo
Old 04-28-2007, 09:58 AM
gadgit's Avatar
clutch problem.
This appears at this stage to be the hydraulic problem if the cars been standing around doing nothing for a bit.
Bleed the slave cylinder and run some new fluid through the lines till it comes through the bleed screw. Try it again and see what happens.
I doubt the clutch system would just fail without some warning before this.
Come back again after you try this!
gadgit.
Old 04-28-2007, 12:15 PM
Look on the carpet under the clutch pedal for a puddle of brake fluid. Same with the slave cylinder. This is not a definitive test but it might give you a clue.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 04-28-2007, 01:48 PM
there was not a puddle...but i ran my hand up the clutch lever to where it meets the firewall and when I pulled my hand away there was some oil on it....is that normal??
1986 944 non-turbo
Old 04-28-2007, 04:06 PM
Nope.....
Jach the car up and watch the clutch lever at the bell housing for movement while someone pumps the clutch pedal.
87 924S
82 924-Gone.
Old 04-28-2007, 04:27 PM
Just thinking out loud
mattdavis11's Avatar
My guess is the clutch fork broke. Do as Jon says.
91 FJ80
84 Ram Charger
Old 04-28-2007, 07:21 PM
thanks for the help....I won't have time to check it this weekend, but I will give an update whenever I get a chance!
1986 944 non-turbo
Old 04-29-2007, 09:55 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
