I gave up ....
I never did find what was causing the fuel pump not to work...
I just wired the fuel pump up to a switch and fuse and the car runs and drives fine ... UGH I hate having it like this but whatever
-2002.5 GTI VR6 24V 6SPD -Kalahari Beige 89 Porsche 944S2 -87 VW GTI 1.8 16v -2007 Ford PIMP(free)star ...company car.... -1999.5 Jetta VR6 |
On my car I had a problem with not being able to get the fuel pump to run. I checked fuses and the DME and traced and tested the entire circuit. I ended up under the dash where someone had put a toggle switch in for a "anti-theft" device, I flipped the toggle and presto! It worked. Sorry to hear about your luck, but your fix will serve just fine. I was pretty close to doing the same thing when I had problems with mine.
Brian '86 944 NA '94 Jeep Cherokee 3" and 31's '86 Chevy C10 425hp '98 Dodge Neon (the wife) |
Will work for parts
Sounds odd, but did you ever replace the ignition switch? In our race car part of the ignition switch went bad and caused the lack of brake lights and instruments. This was traced due to the fact it wasn't sending 12v to the relay. Could be similar?
-Greg
'88 944 240,100 miles -race car '05 Boxster 110,000 - Daily Driver '74 911 Targa - long term project |
Ill check it out once i get a chance ...i just wanted to the thing to run. I just need to get a new tire and shes road worthy
Cooler is back, NICE
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
The logic to the original wiring provides that when the engine stops the fuel pump shuts off, like in an accident. Worst case is an engine stall from reduced pressure caused by a fuel leak somewhere on top of the engine, with your switch the pump just keeps pumping. Add a random spark and the 944 is toast.........
Keep lookin, it's worth the effort. Jon
87 924S 82 924-Gone. 80 924 parts car-Gone. |
Besides the safety aspect, your insurance won't cover anything.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 03 Altima Tin box 05 Pontiac Sunfire, 64 VW dirt buggy |
insurace???
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked ![]() |
if his car goes up in flames.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Thread Tools | |
Rate This Thread | |
