Eldorado's Avatar
car pulls to the right slightly when pressing brakes
what would cause the car to pull to the right slightly when depressing the brakes?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-15-2007, 02:00 PM
Send a message via AIM to Icey1174
Sounds like the right side is grabbing more than the left. Possible air in the lines, a caliper hanging up on the left side, a bad caliper on the left side, a leak on the left side. Check the pads, the rotors, and the lines. If the pads and rotors are good all the way around try bleeding the lines.
My brother was complaning of the same problem. Turns out he has a bad line on the oppsite side that the car was pulling.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 05-15-2007, 02:39 PM
All good info. ^ ^ ^
Check your tire pressures too. It sounds overly-simple, but a low tire on the right front could produce similar symptoms. It's a cheap and easy thing to check...my favorite kind!
-- Jim
1983 944
Old 05-15-2007, 03:12 PM
Simple problems are the best ones to have!
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 05-15-2007, 03:15 PM
definitely check the tire pressure- that happened to me with a slow leak a couple weeks ago. My car also pulled slightly to the right during braking before I changed out my old rotted control arm bushings.
-Gabe
-black 1988 924s, 944 turbo sway bars, LSD, gunmetal phone dials-- SOLD to some people who cannibalized her
-1987 MR2
---ONLINE REP FOR RADMACHER PORSCHE SERVICE IN TUCSON---
Old 05-15-2007, 04:25 PM
Send a message via AIM to hpaulb
Have you inspecded the pads. They will usually tell you if one side is grabbing more. This problem is seen with stuck caliper slide rails.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 05-16-2007, 10:53 AM
Re: car pulls to the right slightly when pressing brakes
Kyle, take the car for a drive taking care to use the brakes from time to time, when you return home feel the side of each front wheel to see if they are roughly the same temperature. If one is noticable warmer than the other you have a "sticky" caliper and it may require rebuilding or replacement. I do this on all my cars with disk brakes, easy way to tell if you have caliper that are starting to seize up. As expected the rears will run pretty cool compared to the fronts.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 05-16-2007, 04:53 PM
