crankshaft interchangeability
hey guys, getting an engine for a rebuild, its from 87 924s, one thing its missing is a crankshaft as it was used for another '87 engine. Could I use a crankshaft from my '84 944 for that engine during rebuild?
Thanks.
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 05-15-2007, 07:53 AM
Not Special
I'm uncertain, but I believe the cam housing/cam in the 8v 944 and the 924s would be the same. Which is good, because I'm looking for a cam housing.
I'll let the smart people confirm/deny that, though.
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen
Former: 1985/1 Porsche 944 - Graphite/Black
Old 05-15-2007, 08:15 AM
can any of the "adults" pipe in and let me know if thats possible?
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 05-16-2007, 08:31 AM
Send a message via AIM to hpaulb
Dan, both have identicle drive trains. Yep, same crank. Why did he need a crank. Usually they go together? i.e. #2 bearing spun.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
03 Altima Tin box
05 Pontiac Sunfire, 64 VW dirt buggy
Old 05-16-2007, 10:20 AM
Dan, both have identicle drive trains. Yep, same crank. Why did he need a crank. Usually they go together? i.e. #2 bearing spun. The 87 will have the updated spring tensioner on the timing belt or the mount for it if it's missing. That means some of the rollers on the front will be different. I have a spring tensioner if you need one.
Also have a spare cam tower assemly if somone needs it? But I'm in Ontario
98 BMW 740i
03 Altima Tin box
Old 05-16-2007, 10:27 AM
hey Paul, cool that will work, Guy took off the crank for another engine he had, thats where he spun a bearing so he used this engine as a donor. As for the spring tensioner, he says there isn't one, not sure if its because its a 924S or maybe because its an early 87 engine, but either way if everything checks out and in the end I need a spring tensioner, I will call you Paul.
Dan
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 05-16-2007, 11:32 AM
