crankshaft pulley removal
So I started with a broken timing belt. Then in the process of removing the head I found a lovely surprise from the original owner... Stripped out camshaft bolts!!! I probably could have found a way to work it out but I decided to just rebuild. I removed the engine, I have the intake/exhaust off, the camshaft is now off, head is in the machine shop, I just got all the rebuild stuff in the mail but I am getting hung up on the crankshaft pulley. I've read both that you need a flywheel lock to stop the engine from turning while you remove the pulley bolt, and also that you can just use a screwdriver or allen wrench to jam it up where the starter motor is installed. I've tried the latter cause I don't have a flywheel lock and it seemed to work okay but I could not torque the bolt off when I was jumping up and down on the end of my torque wrench. Is there something I don't know about this pulley like is it reverse threaded or anything? Also do I absolutely need a flywheel lock or is the problem just a stubborn bolt.
Chris
84 944 |
Hi, I was able to have a friend hold the flywheel in place with a screwdriver while I was able to loosten the bolt. The bolt is torqued on at 150 which is quite alot! Try it again. I am pretty sure if my memory serves me correctly it is anti clockwise to get it off. I messed up a new seal trying to put it on after a front end seal job. You will have to carefully remove a sleave, put the seal in and then re put in the sleave.
I just when through this same thing doing a top end job because of a stripped timing belt. I got the crankshaft bolt to come off very easily using a 1/2" air impact wrench without using the flywheel lock. It is definitely not a l/h thread....put the car in 1st gear and give it a go. If you don't have an impact gun and are using a breaker bar, you will need to install the flywheel lock. When reinstalling the bolt you must use the flywheel lock to torque the crankshaft bolt properly to 154 ft. lbs or you risk having oil pressure problems because the oil pump is driven by friction only. Don't cut corners with this operation.....if you don't have a flywheel lock, you can get one pretty cheap and fast from Arnnworx. Also, don't forget to put a new o-ring on the forward end of the oil pump drive gear.....it's very small and easy to miss.
1988 944 Turbo Guards Red - Black Leather Autothority Stage 2 Chip Set Weltmeister Strut Tower Brace 1984 944 - Sold to rcecale |
Yea I too used a 1/2" air impact gun, It came off without a problem and I didnt need to hold the flywheel. I love air tools ;-)
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
You don't need to take the pulley off to replace the timing and balance belts. If the crank seal is good I would not remove the pulley.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Your looking at just a stuborn bolt. As the others said, if your taking it off to replace the seals, remember how it goes. Done a few and the oil pump gear never want to go all the way in. Had to play with it for awhile. Shaft key turns the oil pump. Torque just holds it in place.
87 924S 107k (miles) yellow 1969 Firebird Coupe (Full frame off restoration.) 98 BMW 740i 2020 Subaru Outback and 2019 Crostrek. |
There is no key way in the oil pump sleeve. The 150 lb's torque is the only thing that keeps it from spinning. Not my idea of a good design.
I always thought it was stupid
^^+1
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
I just went through this on a short block I bought. I recommend buying or borrowing a flywheel lock. It is not too expensive and I have used mine numerous times over the years. On the short block, an impact wrench would not budge it and I broke a standard socket using a cheater bar. I finally heated it and put a 6 point impact socket on my cheater. It took 4 feet of pipe and all of my 220 pounds to loosen it.
Alright guys, thanks for all the help I will give it another shot today after work and let you know how it goes
84 944 |
