Writer/Teacher
First oil leak in the new car?
A few days ago while I was driving I noticed a faint burning oil smell. Fast forward to today. After my car warms up, I notice the smell again. I open the hood to see if there's anything I can spot, and there is a little bit of smoke coming from down by the exhaust manifolds.
It seems that oil is leaking from somewhere and dripping on the manifolds and then burning off, but I haven't had time to put the car on jackstands yet - and there is no oil spot underneath the car when it is parked. Moreover, after I drive the car for awhile the oil smell seems to go away, almost as if the oil has burned off. I checked the oil level, and it was only slightly lower than normal, and this car DOES burn a tiny bit of oil (a quart every month to two months). Just wondering if this is a common 951 leak, what I should look for, etc. ![]()
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
Not Special
I sound like a broken record, but...cam gasket? There are two - cam tower gasket and the back of the cam tower. Know how long it's been since it's been replaced?
Current: 1989 Porsche 944 S2 - Baltic Blue/Linen Former: 1985/1 Porsche 944 - Graphite/Black |
Writer/Teacher
The car's service records show "#1-2 Rear of cam box - #2 pan gasket leak" was repaired in 2002, at 64K miles (100K on car now). How quickly do these go?
Politically Incorrect
Apparently, this gasket is a common cause of the leak you describe. I paid a dollar and change for it - from the Porsche dealer.
4th hole myth BUSTED (with pictures!)
Edek '87 924S '91 535i |
Writer/Teacher
Is this a repair I should tackle myself? How much would labor be at a shop?
CJ - You were about to turbo a N/A. This is cake.
Writer/Teacher
haha. Okay, well I know I CAN do the repair, but keep in mind that the 951 is my only mode of transportation for the time being. In other words, I can't afford to have it off the road more than a day or two, and I have to get to and from work every day.... so I can't afford to screw anything up....
Not Special
I don't think it's that hard; can be done without taking the cam tower off.
Writer/Teacher
Oh cool. Can anyone point me the *best* step-by-step on this? Clark's Garage doesn't seem to have it. I'm sure the factory manuals have it, but the factory manuals leave out a lot of details that DIYers might need.
The bottom screw is the tough one. It can be time consuming because it's hard to reach and there is very limited space for tool movement to tighten it. Make sure you have the lock washers for the screws too. There are three screws, two on top and one on bottom. A mirror works well to see the bottom hole. Make sure you get the hole with the threads on the bottom.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Not Special
And, just while we're throwing complications on there, be sure you torque everything to the correct amount or it'll leak again.
Does anyone know the correct torque for these screws? I have been looking long and hard for them and I can't find anything,
Not Special
It's on clark's. in INCH-POUNDS. Get a 1/4 drive torque wrench. it's something like 6 Ft-lbs, or 72 in-lbs.
Writer/Teacher
I will likely do this myself, but if I do bring it to the mechanic, how much would I likely pay in labor?
Do you happen to have the link to Clark's? I can't seem to find it on there. And I thought I read the whole site.
Not Special
Thanks. I went through the whole manual there again and found it. I ordered two gastkets, one for the "next time." I am new to doing this type of engine work. What is a normal procedure for installing a cork gasket? I have heard of people putting oil on them so "they don't dry out," and I have heard of people using RVT so they will not leak. I prefer not to use RVT, but I am wondering about using oil on the gasket prior to instalation. Maybe it's all a matter of preference. The other cam gasket clearly states to make sure both surfaces are free of sctraches, are clean, and are dry, or the gasket will leak. The cork is obviously a different type of material.
Not Special
I just put it in and torqued it down.
thanks, that's the plan then!
Do not oil a cork gasket! It will leave a molecular path for the oil to seep out through.
