sketchers356's Avatar
Clutch Pedal Issues
Hi,
I have been having some troubles with my clutch pedal recently on my turbo. The clutch does not spring back fully to level with the brake pedal, I have to pull it back with my foot to make them even. Also, the clutch does not disengage until it is almost fully depressed and seems to be getting worse. I fear that soon I will depress the clutch fully and it will not have enough travel to operate the clutch.
Anyway, I am not sure what the problem is. Do I have to adjust a linkage or does my clutch master cylinder need to be rebled or replaced. I'm not sure what the problem could be so I thought that I would ask you guys for some help. Thanks again!
Alexander
'75 911S Targa
'86 951 SOLD
Old 05-22-2007, 04:25 PM
Parrothead member
VINMAN's Avatar
Clutch master cylinder. Change the slave too, while youre at it.
Vinny
Old 05-22-2007, 04:30 PM
Eldorado's Avatar
check the fluid level... bleed the clutch. if you dont get any improvement, replace both cylinders.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-22-2007, 04:53 PM
Send a message via AIM to bholmes
^ +1
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 05-22-2007, 06:25 PM
ragreene801's Avatar
This happened to me a couple of times and was able to just fix the slave cylinder. While you're in there, it would not be bad to change both, though.
'83 944 Silver/Black
'95 Grand Cherokee
Old 05-23-2007, 04:23 AM
Misunderstood User
Agreed. Change both master and slave cylinder.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 05-23-2007, 04:48 AM
87924gt's Avatar
It might also be that really cheap clutch replacement. Mine is doing the exact same thing. I replaced both cyliders and bleed the livin' krap out of the system, but the problem's still there. I noticed mine while going into turn 7 at Sebring last month. Boy is that a confidance builder!!
Steve Ed
My life is great!
Prev. rides - 87 924GT, 86 Carrera, 69 Targa, 85.5 944 track car, 86 951
84 Triple Black 911 - Current
Old 05-25-2007, 07:32 AM
Eldorado's Avatar
are you bleeding the clutch properly?
Kyle
Old 05-25-2007, 01:10 PM
