Craptastic
So my daughter and I set of for the holy grail this morning. New Pelican Parts came in yesterday and we are going to make this 85.5 944 run.
This car has not run in 8+ years but I have drained the 8 year old gasoline/varnish cleaned the fuel tank with lacquer thinner. Cleaned the rest of the fuel system with lacquer thinner. Replaced the fuel pump, the fuel filter, the distributor cap, the rotor, the plug wires, the plugs, the timing and the balance shaft belts, the throttle body mounting gasket, the air intake boot, and cleaned the throttle body.
I'm feeling good about a successful launch.
No Start.
Pull a spark plug - no spark.
Check the coil after getting the rickifricafraking cover off of it and its OK. I had my daughter crank while looking at the coil primaries with a VOM and no signal at all. Next I went to find the DME brain to see if it had bad connections. Haynes, of course, said it was under the dash to the left of the steering column, Clark's helps me out that, no it is under the carpet on the passengers side of the vehicle.
Pulled the carpet and I have a DME connector but no DME.
I sorta figure that is why I have no spark and why I had to jumper the DME relay to get the fuel pump to run.
So now the big question. Which DME do I need?
The car is a 1985.5 944, N/A, with an automatic - oh, and it is red.
From grousing around the internet I figure it to be a Porsche P/N 944.618.121.04 and a Bosch number 0 261 200 077.
Can anyone confirm that this is the correct part number for my daughter's car?
TIA,
...Lee
Old 05-19-2007, 12:45 PM
winter-hater club member
nynor's Avatar
i *THINK* you can use any DME from an NA after 85.5, except the '89 or from an S or S2. you should be able to get one off of eBay relatively cheap.
"COOL PRIUS!" - Nobody Ever
Old 05-19-2007, 12:58 PM
Blondie's Avatar
$150/DME..We've got a ton lol
'86 Porsche 944, Guards Red
Nancy is currently [going in for the final 'once over' this week..]
AFJuvat - "Thou art affirmed: Go forth and inject fuel my son." LOL
Old 05-19-2007, 01:27 PM
Gon fix it with me hammer
svandamme's Avatar
aren't there different DME's depending on CAT or not CAT , US spec or Euro spec?
Stijn Vandamme
EX911STARGA73EX92477EX94484EX944S88NOW987C2007
Old 05-19-2007, 01:29 PM
could your DME be under the dash on passenger side
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 05-19-2007, 01:31 PM
nynor's Avatar
yeah, but you are not going to run into too many that are non-cat in the states. besides which, if you did, it would still work. ask me how i know
Old 05-19-2007, 01:47 PM
fast924S's Avatar
Send a message via AIM to fast924S
That sucks, Who takes the DME and leaves the rest of a good car LOL, I say, while your at it swap that auto out. ;-) j/k
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 05-19-2007, 01:51 PM
Hi, you gave the correct numbers for your computer. 924S uses the same computer as well. Same computer for manual or automatic 944's
Old 05-19-2007, 02:27 PM
Deplorable Member
Porsche-O-Phile's Avatar
Early '85 has the DME under the dash. Late '85 and newer have the DME in the passenger's side footwell. IIRC any 85.5 n/a DME should work fine.
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 05-19-2007, 02:43 PM
Ornery Bastard
The good news is that it shouldn't be too hard of a part to locate.
eBay item Number 320112134300
P/N 944.618.121.04 from the photos. Not my own auction.
Shifting is an art. Learn it, love it, live it.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 05-19-2007, 03:49 PM
I'm with Bill
Rick V's Avatar
When I re-built the head on my S, my daughter helped me do it. I had her lapping valves. She also helped me get to some of the small bolts, that my hands have trouble with. She wants to trade me her Corolla for the 44.
Old 05-19-2007, 05:01 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
This is just an aside, but when I chipped my 83 944 years back, I discovered that my DME was from a 1986 car. As far as I know, the AFM was correct for 1983, so it appears that these cars will run fine on any year's DME as long as it is correct for the model. I would, however, err on the safe side and get a 85.5+ DME.
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 05-20-2007, 07:33 AM
Just thinking out loud
mattdavis11's Avatar
I would concur with CJ, but I would also move the DME to a better location, like under the steering wheel. I never will understand why they moved them.
91 FJ80
84 Ram Charger
Old 05-20-2007, 07:55 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
CJ - the late cars will NOT run well with mismatched DME/AFM combos... IIRC it is possible to run the car with the combo you had, but i've tried the other way and it's not great at all (late AFM with early DME).
you'll definitely need an 85.5-87 DME
Mike - Flight Instructor, A&P Mechanic, Fuel Injector Service Specialist
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
'99 VW Cabrio - green/tan - daily beater
'83 944 - zermatt silber/black - Dad's 40k mile time capsule. purchased in 09-1998 @ 18k
Old 05-20-2007, 09:22 AM
Ornery Bastard
I can get my DME and KLR out in 10 minutes from the floorboard location without having to contort myself to get under the steering wheel. It's much easier to get at in the floorboard location IMO.
As far as relocating it goes, you'd need to do some modifications to the wiring harness to make everything reach. I really don't recommend it.
Old 05-20-2007, 02:00 PM
nynor's Avatar
^my thoughts exactly.
Old 05-20-2007, 02:28 PM
