Car won't stay on!!!!....
I'm having a bad monday. Everything was fine and all of a sudden the car wont stay on. Me thinks bad Idle Speed Valve but what do I know. Any thoughts. To top it off my turn signals wont work either. I couldn't imagine they'd be related. I checked all the fuses and their good. All the lights work but signals don't work...it stays steady when they should be flashing.
88 928 S4 Black, Black and Grey Interior
Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover.
Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red
Old 04-09-2007, 06:57 PM
That Guy
Techno Duck's Avatar
Change the flasher relay.
Other than that, not sure about your running issue.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 04-09-2007, 07:00 PM
Thanks Techno...I'll swap that from my NA parts car.
However,
This is effing wierd...its back to normal but WTF was that. It started but wouldn't stay on..meaing I had to keep reving her otherwise it would die. Well I just drove it on the highway from visiting the GF and by the time I got off the highway its back to normal...so WTF could that have been. A clog in the fuel line...filter. Its a new 3bar FPR...it was certainly fuel related. Thoughts.
Old 04-09-2007, 09:05 PM
winter-hater club member
nynor's Avatar
not sure why it would be fuel related, being that it would stay running as long as you kept it revved up.
"COOL PRIUS!" - Nobody Ever
Old 04-10-2007, 10:19 AM
Ornery Bastard
Fuel pump?
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 04-10-2007, 02:27 PM
nynor's Avatar
if its the fuel pump, revving would cause it stop running faster, seems to me...
Old 04-10-2007, 02:38 PM
Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
Gummy AFM?
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 04-10-2007, 03:05 PM
gummy afm..ill check that
Old 04-10-2007, 03:33 PM
BTW I replaced the flasher relay from my parts car...all good. Turn signals work again.
Old 04-10-2007, 03:38 PM
Ornery Bastard
If the pump is delivering marginal pressure, sometimes revving will keep an engine running because it causes the injectors to fire more. I'd definitely check for proper fuel pressure at the rail just to be sure.
Old 04-11-2007, 08:26 AM
Politically Incorrect
onZedge's Avatar
You didn't exactly say, but did it run bad cold and then OK once warmed up? If so, it might be the DME temperature sensor.
Edek
'87 924S
'91 535i
Old 04-11-2007, 09:47 AM
No it experienced problems after the car was already warm. It started after I got off the highway and oddly it fixed itself afterwards when I went home from visiting the GF.
Old 04-11-2007, 10:24 AM
nynor's Avatar
could it be trying to tell you something about the GF? JK!
very odd problem.
Old 04-11-2007, 11:09 AM
It happened again. Same scenario this time I noticed something strange. When I have a full tank. I don't notice a problem of the car bogging past 3k rpm. When I'm at a 1/4 tank and last time it was lower thats when I noticed the problem. Also I ran the car at full boost to like 6k rpm like I did last time and same thing happened where it didnt wanna stay on after that run. I'm wondering if I have some crap in the tank that gets kicked around when the tank is lower.
Old 04-13-2007, 10:30 PM
nynor's Avatar
there is the ping pong ball in the gas tank trick... when the fuel level gets low, the ball occludes the fuel pickup. real fun on the old regular fuel cars with the bigger filler tubes.
Old 04-14-2007, 06:19 AM
onZedge's Avatar
I don't have any experience with turbos, but how old are the hoses and air boots? How old is the fuel filter? Did this problem start AFTER you put in a new 3.0 Bar FPR? Is the distributor rotor loose?
Edek
'87 924S
'91 535i
Old 04-14-2007, 12:01 PM
I just swapped the 3.0 bar with the regualr one and it still did same thing gotta be something else.
Old 04-14-2007, 01:20 PM
BAck with same issues...this time my tank was full so thats ruled out
Old 05-19-2007, 12:12 PM
Well it was a tube that goes into intake. All is well an no more issues at high RPM. Who Hoooooo!!!!
Old 05-20-2007, 06:58 PM
meister member
speedracing944's Avatar
Glad you got it fixed. I thought it was maybe vacuum related.
Got your voice mail as well.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 05-20-2007, 07:58 PM
