74goldtarga's Avatar
Rear ride height adjustment, camber, toe help.
I am trying to figure out how to adjust the rear ride height, camber and toe. I now (proudly) own the P221 tool and have a camber gauge coming in the mail. I also made my own toe gauge. There are too many bolts back there and I am not sure which ones to loosen/rotate and in which order. Anyone have a picture or know where one is that can give me an idea how to make adjustments. Thanks.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 05-21-2007, 09:56 PM
Misunderstood User
Dear Targa,
I have attached information that will help you. Techno Duck gave this information because I am doing the same thing. I'm passing on the info to you.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 05-22-2007, 06:42 AM
Tidybuoy's Avatar
Just out of curiosity, does it matter if the tank is full or empty?
Vern
'06 Cayman S - Arctic Silver, "R" Springs & Struts, Spyder 19" Wheels, 82mm Plenum & Throttle Body.
'74 911 Coupe - Silber Metalic, PMO ITB, Electromotive Mgt
'16 BMW R Nine T (the fun one) & '17 BMW G310R
Old 05-22-2007, 10:11 AM
Misunderstood User
Got more information for you on suspensions . See attached link.
The weight of a gallon of gas ranges from 5.8 to 6.5 lbs/gal. If you consider the tank capacity of 14 gallons, the weight ranges from 84 lbs to 91 lbs. I don't think that will make a difference. If you are worried about it, I would go with a 1/2 tank.
You should get the car realigned after you make your modifications.
http://dspace.dial.pipex.com/prod/dialspace/town/pipexdsl/s/asco96/944t/suspension.htm#Ride%20height
Jim
1983 944n/a
Old 05-22-2007, 11:38 AM
Gremlin85's Avatar
Send a message via AIM to Gremlin85 Send a message via Yahoo to Gremlin85
good info
1987 944 N/A Gray on Burgandy, Manual. Koni adjustables, lowerd. 16" two-piece Five spoke French rims. BROKEN.
2004 Pontiac GTO. 40th Anniversary Pulse Red 6-Speed with Pacesetter Long Tube Headers, catless mids, drag springs, DBA Slotted Rotors with C5 Hawk Pads. Tuned By Staging Lane Performance.
Old 05-22-2007, 12:52 PM
Great help guys, love the articles as well. Thanks.
Old 05-23-2007, 07:03 PM
