Dave101's Avatar
Send a message via Yahoo to Dave101
Throttle cam
I installed throttle cam on my car the other day........ And all i can say is WOW. It's like a whole nother car. The throttle response is nice. I did have to drill the holes out of the new cam just a little though as it wouldn't fit over the post and the cable wouldn't fit either. But after drilling them out and adjusting the cable for proper idle, which I believe is at about 900 rpm's it works great! I truly recommend it to anyone that hasn't already done the upgrade. The nice thing is if you don't like it for some reason or another it is a cheap upgrade and the reversal would be very easy to do.
Dave
1984 944 N/A Black (Daily Driver.)
New Users please add your car's year and model to your signature line!
Old 05-21-2007, 01:54 PM
SoCal Driver's Avatar
I drove a Toyota today and all I can say is Wow! It's like a totally different car from the 944!
You don't adjust the tension on the cable or the hard stop for the throttle valve to set the idle.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
Never break more than you fix!
Old 05-21-2007, 02:44 PM
Just thinking out loud
mattdavis11's Avatar
Yeah, you don't do it on a Toyota either.
That stopper under the go pedal can be deleted now.
91 FJ80
84 Ram Charger (now gone)
Old 05-21-2007, 05:43 PM
Dave101's Avatar
The cable was too tight with the new cam on and it was ideling at 2500 RPM's. What was I supposed to adjust?
Dave
Old 05-22-2007, 06:01 AM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Well, the cable's slack is adjustable at the firewall, and the idle is adjustable two different ways - by the throttle stop screw and by the idle adjust screw itself
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 05-22-2007, 06:58 AM
Dave101's Avatar
The tight cable was pulling the trottle cam back away from the set screw. After adjusting the cable it now sets next to the idle adjust screw.
Dave
Old 05-22-2007, 07:03 AM
You did the right thing Dave the cams are completely dirrernt and use a different amount of cable length.
Just double check to make sure the cable pulls to WOT I use alittle baseball bat between the seet and pedal.
Sid
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 05-22-2007, 08:31 AM
Dave101's Avatar
Good idea. I hadn't even thought of WOT. I will have to check that. It's nice though not having any delay when i give the car gas. Seems much more "normal" now.
Dave
Old 05-22-2007, 10:04 AM
Send a message via AIM to bholmes
I did the free-bee mod to my throttle cam to do essentially the same thing. It was much improved I felt. Snappier to say the least. Also it made shifting easier for me as the throttle progression seemed more logical/linear.
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 05-22-2007, 06:47 PM
