auto trans help...pleeeeeeeeeez
ok, I picked up a 86 944 auto trans,the previous owner said he had problems with slipping up hills etc.When I go through the gears there is no noise of any kind.
Ok im no expert but wouldnt the torque tube spin? Is there anything I can do to diagnose the problem.
Anything to point me in the right direction would be appreciated.Thanks in advance
07 Ranger Super Cabriolet
Parting a 85.5 and 2 86 944's ..2 automatics, 1 5 spd 87 944 S
06 Harley Davidson Heritage Softail
Old 03-31-2007, 02:38 PM
SoCal Driver's Avatar
AAMCO
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-31-2007, 03:33 PM
I relaced the aamco already from the last time and it still isnt running
Old 03-31-2007, 05:41 PM
winter-hater club member
nynor's Avatar
oh boy...
"COOL PRIUS!" - Nobody Ever
Old 03-31-2007, 05:55 PM
lol
Old 03-31-2007, 07:47 PM
Greasy Member
many944s's Avatar
ROTFLMAO!!
::edit:: wow didn't read your response....
Sometimes you can get lucky by replacing the transmission filter, but more often than not it needs to be taken to a tranny shop to be serviced.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 03-31-2007, 08:59 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Yeah, that was pretty funny. To answer your question although I don't understand the reason for it. Yes, the torque tube will still spin....it's just the tires that will not.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-31-2007, 10:06 PM
Ok ok ok I can take a hint,take it in. The previous owner said he did the fluid and filter. I was just trying to see if it might be the torque tube since my 928 had stripped splines but a good trans.Im going to just look for a used one and do a swap.
Old 04-01-2007, 10:02 AM
The 944 does have a rubber damper just behind the motor that does give out sometimes. Usually when it slips, you feel a clunk (so I'm told but I've never personally felt it) and you will see rubber chunks under the car just behind the motor. If you want help finding a transmission, let me know.
Tom
Old 04-01-2007, 12:57 PM
Here is one on evilbay at the moment.
http://cgi.ebay.com/ebaymotors/Porsche-Automatic-Transmission-Transaxle_W0QQitemZ320097916833QQcategoryZ33727QQr dZ1QQcmdZViewItem
Tom
Old 04-01-2007, 01:27 PM
I seen that trans,thanks. Im in no hurry but thats what I was getting at,seeing if it could be something else.Its in too good of shape to part it.Thanks again Razor
Old 04-01-2007, 01:33 PM
Custom User Title
rammstein's Avatar
Vancity- you get my vote for best post of the year- that made my day! I replaced my midas and my car runs much better now!
Good luck with the car.
Old 04-01-2007, 02:58 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
There are adjustments for the kickdown cable that wildly effect transmission performance. consult the factory manual.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 04-01-2007, 03:09 PM
And Todwic should know!!!
Old 04-01-2007, 04:58 PM
Well after getting it up on stands and checking to see what happens when its shifted,the damper and torque tube must be fine as I can see it rotating through the inspection hole,the shift cable is moving,I was told to check the fluid pump? When I shifted it the fluid in the resevoir dropped half an inch or so,Im assuming that means its pumpn,transaxle has fluid.Guess its pull time.
This is all new to me and I realize most of you do this in your sleep...so bear with the stupid questions or Im gonna go buy a Taurus lol....Happy Easter peoples !!!!!!!!!!!
Old 04-01-2007, 07:30 PM
todwic's Avatar
Seriously, at least try playing with the adjustmenst at your throttle body. the cable thing. I had mine anywhere from "won't shift out of second" to "Where the $#^%!#$^ did reverse go?".
'86 951
Old 04-04-2007, 04:19 PM
Will do todwic,if thats the problem,beeeeeeeeeers on me...of course it will be Canadian lol...
I will chek it out fri...Thanks again
Old 04-04-2007, 07:07 PM
todwic's Avatar
and.........?
'86 951
Old 05-21-2007, 10:47 PM
Eldorado's Avatar
i'm still trying to figure out what word "$#^%!#$^" was..... :P
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 05-22-2007, 12:47 AM
well, to make a long story long. I determined the differential was bad, I bought a used trans and removed the old one, the car is at my place in Washington where I cant do major repairs and got caught lol.
Anyway I would have had to tow it, quoted $500 ish for replacement, pay duty to bring it into Canada and before I could register it I would have had to replace the windshield.
Im parting it now, kinda bummed because its in such good shape,it ran good but I bought it inop and never really knew the rest about the car as far as how it drove,belts etc.
I let it run for a hour straight and it seemed fine as far as temp,starting and restarting, clean anti freeze.
Im just gonna hangout and wait for a nice one to come along.
Need parts? lol
Old 05-22-2007, 04:07 PM
