Send a message via AIM to unsigned
Originally posted by DC9driver
Pulled the old one off today and the wires were brittle and cracked all the way to the connector.. Rather than screw with splicing the wires to the universal, I decided to just replace the whole damn thing with the OEM Bosch 13001. Did some shopping and found it cheapest (129.00) at Partstrain.com.
Good call. Sometimes that is the smartest way to go.
'84 944 Black/Black
_______________
'04 GTO Black/Red - stock
'92 Maxima SE - Is it wrong when your Maxima has KONI Reds and your 944 doesn't?
'94 Maxima GXE - winter wheels.
Old 05-26-2007, 04:15 PM
OK... Here are the results of my failed emissions test:
RPM 2500 - HC PPM 203 (Limit 220) PASS / CO 1.33 (Limit 1.20) FAIL
CO2 14.0%, O2 1.5%
RPM Idle (778) - HC PPM 541 (Limit 220) FAIL / CO 2.54 (Limit 1.20) FAIL
CO2 14.4, O2 1.8
So apparently 2500 RPM is close to passing and idle is terribly out of limits.. Gut tells me that it's got to be the O2 sensor right? seems like its very rich at Idle..
Should have the part next week.
'84 944 N/A
'01 Audi TT Quattro Convertible
Old 05-26-2007, 04:31 PM
Originally posted by ERAU944
if you're going to do that every time you buy parts - you're going to be bending over a whole lot.
What's that? Buying the expensive OEM?
-9
'84 944 N/A
Old 05-26-2007, 04:47 PM
winter-hater club member
nynor's Avatar
does seem rich to me. likely it is the O2 sensor. i suppose it could also be the temp sensor.
"COOL PRIUS!" - Nobody Ever
Old 05-26-2007, 05:35 PM
Check your tps adjustment as well if it is not adjusted right it will overide the idle map.
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 05-26-2007, 06:26 PM
Re: O2 sensor question
I Failed Nevada emissions (horribly) CFC and Co2 levels were nearly double (especially at idle) Car is running a bit rough and idling at about 750
Splice in a Bosch 13913 O2 sensor! Remember to crimp the connection, no solder.
Rough running you may want to unplug the sensor to see if the car runs better .. if it does then it is the O2 sensor... if it doesn't you have other problems you should make sure you do a tune up if you have not already done so and check for air and vacumn leaks.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 05-26-2007, 11:23 PM
