marko's Avatar
Question power steering pump removal
UNCLE!!!!!! How do I get this thing off? I have all the bolts removed. Arrow 1 is as far left as I can go (I've removed the spacer inside the sleeve). 2) Is that a spacer that needs to be removed or is it part of the bracket? The manual says to swivel the pump up and remove the spacer from below, but i don't see another spacer anywhere....
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 05-28-2007, 04:26 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
the spacer/bushing by arrow number two can be punched out with a screwdriver or punch and a hammer towards the front the car. Once it gets moving it slides out real easy.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 05-28-2007, 04:46 PM
marko's Avatar
I tried prying that thing out but it wouldn't budge.. I'll give it another whack....thanks!!!!!!
Old 05-28-2007, 04:53 PM
marko's Avatar
Ok, I got it.....geeeeez, what a PITA!!!
Old 05-28-2007, 05:29 PM
TNT25169's Avatar
no, a PITA is not knowing how to get it out and having someone who is willing to pay $25 for the two sided screw. The first time I did it I used a grinder to cut through the brass bushing, now i know better...
www.apartabove.com
Old 05-28-2007, 10:36 PM
