shbop's Avatar
86' keeps blowing oil filter off
Got an 86' that keeps wanting to blow the engine oil filter off. Oil preasure builds very quickly, and you can actually see the filter start to grow before the base o-ring gives-out. Preasure relief valve seems ok. Any ideas? Thanks in advance.
Jon
Old 05-31-2007, 07:08 PM
There is a diagram of the oil system at Clark's Garage. www.clarks-garage.com The oil pressure relief valve is either bad or is binding. There is an alignment tool that must be used to install the oil cooler housing so that the relief valve installs correctly without binding.
Old 06-01-2007, 03:57 AM
AFJuvat's Avatar
Before you start replacing parts, do a leakdown test on the car.
Also check your oil dipstick - is it wanting to pop out of the tube?
If all of the above check out fine, then replace your OPRV.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 06-01-2007, 04:36 AM
shbop's Avatar
This all happened as a result of having to replace the housing. No problems before. Without the special tool, is it possible to use another pressure relief component to provide the necessary alignment, or is the tool mandatory?
Jon
Old 06-01-2007, 04:53 PM
The tool fits much tighter than the OPRV. I would say it is mandatory, but I guess you could try using an old OPRV. You might get lucky.
Old 06-02-2007, 05:39 AM
Politically Incorrect
onZedge's Avatar
I used to hate buying "special tools", but considering the amount of work it is to get to the point of aligning the oil cooler and the obvious trouble it prevents, the $48 "special tool" is cheap. Maybe you can rent it out later to recoup some of the capital expense. Maybe you could find it cheaper. I hate doing things twice. I now have a tool chest drawer dedicated to "special tools and test equipment". Sorry, I don't have the alignment tool to send you - PO had the dealer replace the seals.
Edek
'87 924S
'91 535i
Old 06-02-2007, 08:02 AM
shbop's Avatar
Thanks for all the replys. I ordered the tool.
Jon
Old 06-02-2007, 01:03 PM
