-   -   DME Failure (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/349749-dme-failure.html)
knights89 06-01-2007 02:02 PM
DME Failure
Hi All,
Just determined that my DME is failing. I noticed in the BMW Tech Articles, there is a rebuild for the Bosche DME. (http://www.pelicanparts.com/BMW/techarticles/E36-DME-Repair/E36-DME-Repair.htm
Pelican Technical Article: BMW DME Motronic ECU Swap / Repair) Has anyone used it to try to fix a DME?
nynor 06-01-2007 02:12 PM
yeah, do a search. people have had success resoldering the connections, etc. if that fails, get one off of evilBay. what car do you have?
knights89 06-01-2007 06:39 PM
Hi Nynor,
I have a 1988 944. Plain jane, no S, no turbo. Interesting though, its more like an 87 - supposed to have ABS - it doesn't, supposed to have airbags - doesen't.
nynor 06-02-2007 05:37 AM
i think they were options. mine doesn't have ABS, but does have airbags (which i promptly disabled).
myskyon 06-03-2007 06:57 PM
Originally posted by knights89
Hi Nynor,
i believe the air bags became standard on the 951 in 87 but remaind and option or the non turbo cars untill 88-89 also if your car has the option for the 30mm steering hub that will delete the air bag wether its standarad or not. but that would only be the drivers side. as for abs the only car to have it standard is the 952 (turbo s). check your option codes on the rear part of the hatch wall under the carpet and look them up.
ERAU944 06-03-2007 07:06 PM
turbo S is not 952 ( i think that's a RHD 951), but yes the only 944/951 series to have ABS standard is the 951S
mlue 06-05-2007 07:56 AM
I believe all Late DME - 1985.5 to 1989 Porsche 944 use the BOSCH Model ML3.1 Motronic software but according to FRFILK.COM different model years use specific DMEs so I don't know how well swapping with a BMW will work out.
Your '88 uses DME 0 261 200 086
For comparison:
'86 uses DME 0 261 200 076
'89 uses DME 0 261 200 089 for the 2.7 litre engine
The only thing you could do is try swapping different DMEs to see if they work but before you do that you may want to try resoldering the connections on the DME out of your own car to see if that will solve your problem. Here is a web tutorial that will get you started.
http://www.rennspeedracing.com/DME_tutorial.html
