Send a message via Yahoo to jhampton
air flow meter
is the 1986 and the early 1983 944 air flow meter the same
Old 06-11-2007, 02:34 PM
Nope.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 06-11-2007, 02:47 PM
SoCal Driver's Avatar
Basically yes. However the resistor that the flap moves the wiper across is cut a bit differently. It's curve is linear where as the early is a bit parabolic. Also a difference in the reference voltages used too. Early is 12 vdc and later is 5 vdc.
You can re-adjust the wiper to track fresh carbon. Directions were at www.frwilk.com.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-11-2007, 03:55 PM
