EMBPilot's Avatar
Send a message via AIM to EMBPilot Send a message via Yahoo to EMBPilot
Horn Fuse intermittent
Last one for tonight guys
My horn fuse has always acted up. i can put a new fuse in, drive around for months, it will be just fine. once i use the horn, i can beep it as many times as id like, at some point after the beeping is over the fuse will blow. Its strange cause it will be fine until i need it, then i can use it to my enjoyment, then later down the road, at some point, the fuse will be blown.... everything else electrical is normal...
I can hear the relay clicking when i push the wheel pad...
1995 993 C2
Old 06-23-2007, 08:25 PM
Send a message via AIM to Icey1174
Relays do click, they are mechanical. You can hear it click all the way inside the car??? Do you hear it click when the fuse is good or bad? Sounds like a short somewhere. They can be a PITA to find but are usually in easy to find spots.
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 06-24-2007, 07:42 AM
EMBPilot's Avatar
it clicks, i can hear it from inside the car, even if the fuse is blown...
1995 993 C2
Old 06-24-2007, 10:41 AM
Is it the relay clicking or the switch in the horn pad clicking?
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-24-2007, 03:09 PM
EMBPilot's Avatar
both of them click
1995 993 C2
Old 06-24-2007, 08:18 PM
I would be a little suspicious of a relay that clicked so loud that you could hear it through the firewall and the fuse box. Sounds like to might have a short somewhere. I would start by looking at the horns. They do get a lot of weather where they are located. Then try looking behind the horn pad on the steering wheel. I have found a lot of electrical problems in the easy spots. Either bare wire or some kind of "junk" causing a short.
John
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
RIP SoCal
Old 06-25-2007, 07:14 AM
