any sheet metal workers in here? amatures ok
Anyone in here mess around with sheet metal?
I need someone to make me a solid nose panel to delete the headlights on my 83 track car. Ideally i would like to bolt it on in case i have to remove it at a later date. Also i may need to remove a fender at some point so i dont want to just weld something up. PM me or post here if youd like this project... I dont have the tools to even mess aroud with it. I can send you my exsisting panel as a template.. although a little banged up at least youd have the shape to work with. Dave
Current: 1973 914/4 project. FOR SALE Last edited by mambodave; 07-03-2007 at 04:30 PM.. |
Greasy Member
I can try to make one on the English wheel, but the leading edge is pretty tricky with the curved lip required... Is there anyway you could use a Carbon Fiber nose panel instead? It may be a few more $$ but would definitely be easier to make. The other option, would be to straighten your current panel and weld in patches where the headlights would be. The seams could then be leaded and smoothed out... just some ideas.
I have a couple of motor swaps on my schedule for later this week, so I might not get a chance to start on trying to shape one til the middle of next week. -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
Getting another nose panel, welding in the headlight areas and grinding the seams is prob the the best and easiest solution. Carbon Fiber is nice too. Carbon fiber will be lighter, but you'll have to make a mold and all that good stuff. The carbon fiber will bee a lot more expensive too.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Non Compos Mentis
A friend just removed the headlights, and used the existing headlight covers.
A couple home-made brackets below to hold them in place. If you need to get rid of the seam, this will not work, of course. He just used a few pop rivets. |
Thanks Guys... Someone on Rennlist sold me a used fiberglass panel (GT racing i think) that was already fit onto a car...so should cure the porblem. If i cant get the fit i want Nick, ill drop you a line...
Dave
Current: 1973 914/4 project. FOR SALE |
very cool
Greasy Member
Just let me know, I may start trying to shape one for the heck of it, it may be something I can offer here at my shop in the future!
![]() -Nick
Greasy Member
Once you have the fiberglass one in place, would you be willing to let me borrow, or sell me your "banged up" one so I can try to get all the mount points correct?
Let me know, -Nick
his is an 83 and the nose piece will be welded on. there aren't really any mount points on it, unless you were to bolt down or re-weld where the previous welds are.
Kyle 2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] // "Never break more than you fix!" - SoCal Driver |
Greasy Member
Ahh, good point! None the less, it would definitely help to make sure the end shape is correct!
P.S. love the tag line! may SoCal's words and ways live on! -Nick
It prob was bolted. The eral ones come spot welded from the factory and the PO prob had to remove it for some reason. They drilled out the weldes and then bolted it back on. It's not that big of a deal. You'll just have to go to the hardware store and get some nuts, bolts, and washers.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal Last edited by Icey1174; 07-04-2007 at 03:26 PM.. |
yea, just take a drill to the spot welds.
