924 +or - ground
have a 1977 924 is it pos or neg ground ? the red cable is bolted to body by battery the black cable goes to starter is this right or did somebody change cables
Old 07-26-2007, 01:55 PM
KY944S's Avatar
Sounds like someone changed the cables. It is a Neg. ground car.
1987, 944S (168,000 miles)..sold
1986, 944na.
My job is a hobby. My 944's are work.
Old 07-26-2007, 01:58 PM
Ornery Bastard
I don't believe that there are any 12-volt cars with a positive ground. I seem to remember positive ground as a 6-volt quirk. I'm likely to be wrong here though since that was before my time.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 07-26-2007, 03:04 PM
Hi, some late 50's or early 60's british cars like a TR3 were 12 volt positive ground. They used to make AM radios that you could flip a switch for pos or neg ground.
Old 07-26-2007, 05:32 PM
Pretty sure it should be negative ground
1978 El Camino 350 4 barrel 3-speed automatic The most expensive Lawn Ornament in my county.
1988 Thunderbird Turbo coupe 5-speed manual 2.3L V4 (The Dirty Bird)
1942 Willis Army Jeep 3-speed manual (you can't get it stuck: I dare you to try!)
1987 924S (My Little Silver Money Eater!) 5-speed manual 2.5L SOHC
Old 07-26-2007, 06:04 PM
Hi, I am sure your 924 is negative ground. I was just saying that they did at one time years ago have positive ground cars to answer an earlier thread.
Old 07-26-2007, 06:27 PM
mgatlag's Avatar
I have a 77 924 as well and it is neg ground. My ground is red as well and black goes to the starter too. You're ok.
Michael
1977-1/2 924
"Better than tea with Miss McGill!!" Go Wings!
Old 07-27-2007, 05:49 AM
