-   -   Control Valve #1 Function Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/357861-control-valve-1-function-question.html)
hermesbooking 07-18-2007 04:23 PM
OK, I was wondering about the Control Valve #1, I think, in the system. Under the hood on the drivers side Outboard. When I got my car, the line that goes from the Vac line from the J-Hose area goes to this valve then goes, looks to be the fire wall. That line was plugged off from the J-Hose area with a bolt, and the valve was not in play. Hooked it up, not sure if it made a diff. There is an adjustible set screw on the top ov the valve. What dose thsi do? THe 2 Vacc canisters on the Fresh air fan assembly have no vac, could this go to this? Have no clue. Thanks Mike
hermesbooking@yahoo.com
onZedge 07-18-2007 05:16 PM
I replied to a similar topic here:
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/335503-charcoal-canister.html?highlight=vacuum
Everything you ever wanted to know about the EVAP system!
hermesbooking 07-18-2007 07:41 PM
Thanks, More than likely the CVI is bad. I have noticed the Idle running a little on the off side. That sould take care of that problem. Now just gotta find one that works. Is it a 100% Important part? Can I get buy with it plugged? Thanks Mike
